IS - 1st Gen (2001-2005) Discussion about the IS models up to the 2005 model
Wheel Offset ?
Old 07-30-07, 11:46 PM
JRyDe
JRyDe's Avatar
Default Wheel Offset ?
hey whats up guys!
Im new here and you guys are probably tired of hearin that so ima just ask my noob question. Im planning on buyin these rims but I dont know what offset to pick. The wheels are 17x7 5x114.3 +38 offset or +45 offset I know both should work and I know 17s are whack, everybody goin with 18s or 19s but i just need to get something im stuck with these 16s. Its between the +38 with 215/45/17 tires or +45 with 205/40/17 tires. Which set would yall pick?
Thanks
Old 07-31-07, 12:05 AM
JRyDe
JRyDe's Avatar
Need Help very soon this guy cant hold these rims that long
Thanks yall
Old 07-31-07, 12:57 AM
dsp979
dsp979's Avatar
If you're looking for a more flush look, get the +38 since it will push the wheels out more.
Hope this helps.
Old 07-31-07, 01:05 AM
JRyDe
JRyDe's Avatar
o im just tryin to make it look proper, make everything function right. like someone said +38s might rub and i really dont understand the offset thing. like i look at these pictures to tell the offset and charts and all and i just dont get it. hey call me dumb but maybe its just summer time and i just shut down my brain in the summer time. no school nah mean. but yeah you sayin the 38s will align with the fender more. cause i was just about to go with the 45s but also people sayin the tires comin with it are too small. hit me back up thanks man
Old 07-31-07, 01:19 AM
dsp979
dsp979's Avatar
stock 17x7 IS300 rims have a +50mm offset, so they sit more inside the wheel well. if you add 12mm spacer, it would have a +38mm offset. This means the actually alloy wheel will sit closer to the fender, giving it a flush look.
The +45 offset is barely discernible from the stock wheels and the rubber is too small. It would tick off more miles that what you're actually driving.
if the wheels are 17x8, you want at least +40 offset, no less.
Old 07-31-07, 01:29 AM
JRyDe
JRyDe's Avatar
o ok i see, like this other dude was sayin with 38s i might require fender work i aint tryin to do that. so would you go with the 45s but with 2154517 tires
Old 07-31-07, 01:38 AM
dsp979
dsp979's Avatar
For non-staggered set (all 4 rims have same size and offset):
17x7 +38 flusher look and should not need any fender work.
17x7 +45 sunk in look, almost like stock
17x8 +40 is lowest offset you want on 8 inch wide rim, and no fender work.
Stock tire size for 17 inch rims are 215/45/17.
If u can wait a few more minutes, i'm trying to dig up a link.
This is for reference.
http://my.is/forums/f95/stock-wheel-...06/index3.html
If you look at pics, stock 17x7s with 50 offset on rear of car at top of the page. If you scroll down, you can see how much the stock rims are sunk in on the front. +45 offset is barely noticeable from that. +38 will be very noticeable.
If you scroll down, he adds 25mm spacers to the rear rims for a flush look. His rims are 17x9s rear ( he had them widened ), so i don't know what his exact offset is for 17x9s.
lowRolliN (12-19-20)
Old 07-31-07, 10:49 AM
JRyDe
JRyDe's Avatar
o ok i see, thanks man 4real and thanks for checking stuff up for me. Im about to go with that flush look just looks better
Old 07-31-07, 01:21 PM
BernieIS
BernieIS's Avatar
Good thinking, flush is better. Post some pics when you get them mounted.
Old 12-15-09, 10:25 AM
TinyBuff
TinyBuff's Avatar
sorry, i know its a old topic but i was just wondering.. what if u have flushed rims and u have. ALOT of weight in your car.. will it hit the fenders? i was planning to get 17x7 38 offset.
Old 12-19-09, 10:48 PM
BOXCAR
BOXCAR's Avatar
17x7 38 is not even a concern. If you have alot of weight in your car and its cambered properly and rolled/pulled it will simply tuck itself in like a frightened turtle.
Old 12-21-09, 12:10 AM
VinnRock
VinnRock's Avatar
lol 17x7 is no where near flush you gotta pay to play
its like putting a pizza cutter on your car and pushing em out a little more looks stupid
Old 01-04-10, 07:32 PM
00altezza
00altezza's Avatar
ok..so this whole thread is about 17" wheels...how bout if i wanted to put 20"x8" would i have to do anything to the fenders? my car is stock rightnow, not lowered or nothing and am not planin on lowering it. i just wanna put some 20s on it. thanks
Old 01-06-10, 12:48 AM
white_is
white_is's Avatar
20's look stupid on an IS.
If you get a 20x8 +40 to +50 offset it will be fine. As long as you run like a 225/30/20. Or whatever is comparable to the OD of stock tires.
Did I mention it will look stupid?
Old 01-06-10, 07:03 AM
00altezza
00altezza's Avatar
how and y would it look stupid? that part i really dont understand...
Quick Reply: Wheel Offset ?
