10.5" wide rims on is300!?!?
i want to buy a set of rims which are staggered but the rears are +35 10.5 width 18's... i want to know if any of you have put 10.5's on the is300 and in any offset close to this. and if so post pictures!!! or call me foolish. if they fit i dont want to pass this deal up.
I know from experience that most wheels on an SXE10 in an 18x9.0 (or bigger width) +29 (or smaller) offsets will not clear the fenders at all, even if they are rolled and pulled. If you go too low in the offset, they wont clear the calipers.
You can find several wheels companies that make a 9.0" or wider wheel that will fit if you are running a +40 or larger offset, but you will need some agressive fender pulling, or go wide-body (If you are planning on going wider than 9.0" wide)
wow... this is an old post... sorry for bringing it back from the dead but i thought for reference for current owners, 10.5 +35 225/35/18 fit on the rear and 9 +25 215/35/18 on the front with fender roll and camber on coilovers
i spaced the back out for clearance on the inside
lil' IS300
Wheels, Tires & Brakes Forum
04-24-03 08:07 PM
