IS - 1st Gen (2001-2005) Discussion about the IS models up to the 2005 model
what is your guys tire size?
Old 03-02-05, 03:33 PM
VIP12
VIP12's Avatar
Default what is your guys tire size?
I am buying some rims and they are 19's and I was just wondering the one's that are running 19's on their IS what are your tire size's? The shop said that they recomend that the tire size should be 215/35/19, does that sound right?
Thanks for the help
Old 03-02-05, 04:45 PM
silveraltezza
silveraltezza's Avatar
It all depends on the width for your 19's and offset. For the fronts - if its around 19x7.5 - 8 - 225/35/19 or 235/35/19 . Same for the the rears - if its around 19x8 - 9.5 - size 235/35/19 , 245/35/19, 255/35/19.
215/35/19 prolly work - What width size 19's rims? Size the same all around or staggerd setup?
As for my wheels, I have 19 x 7.5 fronts running 225/35/19 and my rears are 19x8.5 running 235/35/19 (my rear can go as high as 255/35/19 without rubbing).
Old 03-02-05, 05:36 PM
amy011079
amy011079's Avatar
my 19s' have 225/35/ZR19 on them. i would much recomend getting 225 at the minimum. if you have 19x8 or something i would suggest you get 235/35/19s.
Old 03-03-05, 08:15 AM
VIP12
VIP12's Avatar
The rims that I ordered are 19x7.5's and the shop said that they recomend 215/35/19. So I see what everybody else is running now I am a little curious.
Thanks
Old 03-03-05, 08:57 AM
rominl
exclusive matchup
rominl's Avatar
Thanks
215 sounds right. you can probably fit 225 on it if it doesn't rub
Old 03-03-05, 04:30 PM
amy011079
amy011079's Avatar
225s won't rub unless you have the wheel turned all the way one way or another and you're backing up. that was the only rubbage that i had and not enough to really complain about.
Old 03-03-05, 05:45 PM
flipside909
Lexus Connoisseur
flipside909's Avatar
The only way 225 will rub is if you get the wrong offset.
neomedic
03-20-12 10:33 PM
Damaster32
05-09-10 05:36 AM
nMeOnE
01-31-10 08:53 PM
bLingIn3o0
Wheels, Tires & Brakes Forum
02-11-04 08:54 PM
Quick Reply: what is your guys tire size?
