IS - 1st Gen (2001-2005) Discussion about the IS models up to the 2005 model
DIY IS 300 Oil Change
Old 02-12-05, 11:48 AM
clai
clai's Avatar
Default DIY IS 300 Oil Change
Does anyone have any illustrations on how to change oil on an is300?
Old 02-15-05, 08:18 PM
Jurassic
Jurassic's Avatar
easy get a bucket or oil catch can place it underneath the oil bolt...14mm i think...losen and let the oil drain...once oil is drained tighten bolt back up...next losen the oil filter on the drivers side right underneath the intake manifold...may need an oil filter wrench...take that off and make sure you have the right oil filter to replace it with...next lube the gasket on the oil filter with the oil you're using and tighten the new one back up to where you took the old one off...make sure all the bolts and oil filter are tight...and then put the oil of your choice in...5.4qts i think...fill it up and wait a couple minutes and check the dipstick to make sure its right...close your hood and you're done
Old 02-17-05, 11:23 AM
kuuligan
kuuligan's Avatar
piece of cake
Old 02-17-05, 02:12 PM
curiousg
curiousg's Avatar
Make sure to fill the new oil filter with oil before you screw it back on. Otherwise it takes more time to get enough pressure in the system. Fon't overtighten the filter - should be not much more than hand tight.
Changing your own oil is a good idea. My experience with Jiffy Lube et al (no offense to anyone) is that I am likely to get some pizza-faced teenager who tightens everything down w/ an air wrench.
Old 02-18-05, 08:02 AM
Zor Prime
Zor Prime's Avatar
They are also likely to break your hood clip
Old 02-18-05, 08:06 AM
vboy418
vboy418's Avatar
always I love castrol 10w 40 syn... love it!
Old 02-20-05, 03:02 PM
lucino
lucino's Avatar
I always take the oil filter off first, then drain the oil pan.
Brokenis
02-15-17 04:31 PM
morphh
02-01-14 02:34 PM
louiee_g
RX - 1st Gen (1999-2003)
30
02-05-08 07:38 AM
edbro
06-03-07 04:13 PM
Quick Reply: DIY IS 300 Oil Change
