Squeaking sounds after race pipe install
I had a XERD race pipe installed about a month ago, and afterwards I started hearing a squeaking/creaking sound from undernearth and towards the rear of the car.
Well, I had it looked at last weekend. The suspension components are fine and all bolts are tight. It seems to be the exhaust system that's the problem. The bottom of my header (right before the joint with the race pipe) is actually rubbing against the transmission housing! Therefore, after the car's been driving for a little while (after the header has experienced some heat expansion), it actually will touch the transmission bell housing. There is one other area on the exhaust piping that shows indication of rubbing as well.
I've never heard of this happening before. Has anyone else experience this? It may be an artifact of my specific exhaust system combo:
Toyomoto gen 1 header >> XERD race pipe >> Stock b-pipe >> HKS Dragger II exhaust
Please let me know if you guys have any suggestions on getting rid of the noise or any other feedback/similar experience.
Thanks.
Thanks.
the joint probably doesn't match up properly, doesn't the XERD have a much larger flange compared to stock?
i thought i had previously read that XERD components shouldn't be combined with the toyomoto...
anyway why didn't you go with straight toyomoto or straight XERD? i'm sure there are things you can do to fix the rattling of the XERD header/racepipe combo..
I didn't go for the XERD header because it wouldn't have fit with the PLP Vortech kit and it's relocated ABS control unit.
just off the top of my head, the mounting angle on the xerd pipe is differen't from the angle on the toyo pipe.. i've held both in my hands. since this is the case, the race pipe being mounted on the toyo y-pipe is probably not in the 'proper' position/angle.
not sure if i'm explaining this very well, sorry if i'm confusing you but i only slept 8 hours from fri-sun.. hhaha
therefore the question is, why didn't you get a toyo y-pipe?
* I got the race pipe around the time when I was getting detontation and throttle response was poor, so I needed something immediately
* Dave (of Tunedparts.com) had the XERD race pipes in stock, and I couldn't wait for a Toyomoto pipe
* I always kinda liked the look of the XERD pipes more, and the fact that they have a slightly larger diameter
i'll try to get a pic or two for you to show you the differences i'm talking about.
Try some insulation
Also, you can try attraching a piece of heat insulation between the housing and the pipe where it rubs against it. You may have to use a larger piece and hunt for a couple of attachment points. The insulation should both absorb the exhaust heat and prevent.....or lessen.... the annoying noise you mention.
Lexus Connoisseur
Most good performance shops carry the exhaust/header wrap. Most of them are made of weaved fiberglass. You may want to ask and see if Exact can obtain some for you. You can find some rolls of this online as well.
imprtLEXUS
Performance & Maintenance
04-06-07 09:25 PM
