IS - 1st Gen (2001-2005) Discussion about the IS models up to the 2005 model
Traction Control Light Flashing
Old 06-07-04, 10:09 PM
bchau_gt
bchau_gt's Avatar
Originally posted by flipside909
My friend was having the same exact problem on his 02. The TRAC OFF and CEL simultaneously came on with the TRAC OFF flashing. We reset the ECU and it hasn't come back since.
Ya, bulldog, try just resetting your ECU first and see if the lights come back. It doesn't work for me, but my setup is a lot more complex. My CEL and flashing TRAC OFF come back pretty much immediately. I either have a bad O2 sensor, bad O2 sim, or my only remaining cat is burning up.
Old 06-12-04, 08:07 PM
solo
solo's Avatar
Default Re: Traction Control Light Flashing
Originally posted by bulldog13
I was riding down the interstate and my traction control light started flash. What do i do or what does this mean? Thanks in advance
This happened to me awhile ago. My problem was, my brake fluids were low and there was a leak in the anti-lock brake system. One of the hoses were leaking.... check your brake fluids and lines.
-sOlo-
Old 06-14-04, 07:33 AM
B.Diddy
Lexotic Concepts
B.Diddy's Avatar
yes my check engine light has been on for the past month due to a bad o2 sensor, from where the exhaust and intake were changed. but im saying that the track off light is flashing and the traction control is not even working. could this be caused by the bad o2 sensor. i could see that the light would flash with the cel if its tied in together but it would still work right??????? anyways im confused still why it would all of the sudden come on while driving down the interstate and then quit working all together
To make a long story short and to stop the pointless guessing...... Check Engine light + Trac OFF flashing plus diagnosed bad O2 Sensor = Engine Misfire on 1 or more cylidners. The bad 02 sensor is giving the wrong voltage to the ECU and you are misfiring.
Been there, done that. I've since gotten past it. Good Luck.
Old 06-14-04, 09:15 PM
bchau_gt
bchau_gt's Avatar
Hmmm, I'm not sure that's always the case. It's true that a CEL and flashing TRAC OFF could mean misfires, but it could really be anything O2/emissions or A/F ratio related. When I first got the CEL and flashing TRAC OFF, I was getting misfires and I knew that because of the OBDII DTCs I pulled from my car. Later, I was not getting misfires and have gotten some other random codes, but not misfires.
That's what I've learned from having the CEL and flashing TRAC OFF since my S/C install. I've thrown a bunch of different codes.
However, I know B.Diddy has tinkered with his car much more than me, so I may be wrong.
Old 06-30-04, 01:29 AM
AltezzaBob
AltezzaBob's Avatar
if you done **** with your engine ECU, OBD2, o2 sensors and stuff, be prepared for the CEL and TRAC flashy flashy.
But if your o2 sensor is bad, then your car IS misfiring. Like whoever said before it is your O2 sensor at fault primarily here because: If O2 sensor gives off bad readings, then it'll misfire. In turn misfiring is what the ECU does to the engine in the event of TRACTION slip. Traction control, is basically purposed misfiring your engine so the motor doesnt create as much power and puts you back in control..
I hope you understand here...
-Bobby
Old 06-30-04, 01:35 AM
AltezzaBob
AltezzaBob's Avatar
bchau_gt, how'd you get that picture underneath your name for your profile?
Old 06-30-04, 10:57 AM
bchau_gt
bchau_gt's Avatar
Hey Bob, the little picture is just my avatar that you can setup through your forum profile.
whiteisf
IS F (2008-2014)
06-08-19 01:51 PM
fatboyq
SC- 1st Gen (1992-2000)
11-29-06 10:15 PM
jcart05
Performance & Maintenance
06-16-04 09:35 AM
thailegend
12-23-03 01:43 PM
Quick Reply: Traction Control Light Flashing
