HELP!! CEL & VSC & TRACTION Light!!
Old 06-12-15, 01:44 AM
usa5655
usa5655's Avatar
Default HELP!! CEL & VSC & TRACTION Light!!
hey CL! quick questions!
So i had my battery disconnected for over 20mins, and when i started the engine, it was perfectly running fine. but after few miles, CEL & VSC & Traction Lights came on!! does any one experience this? please let me know guys!
my mods are
PPE headers (cat less) had it for few months With no CEL at all
Joe-Z Cat back Exhaust
Old 06-12-15, 05:06 AM
chris07is
chris07is's Avatar
How does the car feels when u drive it? Does it feel normal? Check ur connection again, u might have some loose connection...
Old 06-12-15, 05:20 AM
yjk1975
yjk1975's Avatar
Maybe
1. Battery is no good.
2. The O2 sensor extension is touching at the top.
Old 06-12-15, 05:35 AM
Sceanzo
Sceanzo's Avatar
Go get the code scanned first \_(ツ)_/¯
Old 06-12-15, 08:35 AM
lexuz125th
lexuz125th's Avatar
50% chance bad MAF sensor.
Old 06-12-15, 08:42 AM
KLexus50
KLexus50's Avatar
Get that code checked! It will give you a much better idea of what triggered this event.
For reference, I recently had the CEL & VSC lights on after installing my exhaust (still running stock headers). When I ran the code it came up with a P0031 which lead to bank 1 sensor 1 (upstream O2 sensor in the drivers side header). The code only went away once I replaced the sensor.
Old 06-12-15, 11:11 AM
usa5655
usa5655's Avatar
It drives fine with no problems, but i guess since i have the cel, it wont go into first gear. It would start in second gear.
Old 06-12-15, 11:15 AM
usa5655
usa5655's Avatar
I see i should try to pull the codes first and see.. Hopefully nothing major
Old 06-12-15, 11:16 AM
usa5655
usa5655's Avatar
Originally Posted by yjk1975
Maybe
Thanks bro let me look into that
Old 06-12-15, 11:17 AM
usa5655
usa5655's Avatar
Maf? Hemm...hope so! Im sure its easier to replace than o2 sensors
Old 06-12-15, 11:29 AM
BS ISF
BS ISF's Avatar
get the code!
Old 06-12-15, 12:30 PM
torxuvin
torxuvin's Avatar
Don't worry about the VSC and Traction lights. Those come on anytime the CEL does. Like mentioned before, get the codes read and go from there. Autozone/etc will read them for you for free.
Old 06-12-15, 06:35 PM
Sean
Sean's Avatar
Any auto part store will read the code for you but you might as well buy yourself an obd2 scanner if you have headers and exhaust.
Old 06-13-15, 01:32 PM
usa5655
usa5655's Avatar
So i just pulled the code, it comes up p2238??
Can someone tell me which sensor and where this sensor located?
Old 06-13-15, 02:16 PM
KLexus50
KLexus50's Avatar
A quick search of the forums says that's pointing to bank 1 sensor 1 (same sensor that was my problem). I'd take a look at the wire extensions on the drivers side header O2 and see if anything is loose or melting, first.
Quick Reply: HELP!! CEL & VSC & TRACTION Light!!
