wheel fitment question
hi all, just want to know if these wheels will fit...
8.5J 5/114.3 +38
9J 5/114.3 +45
i dont know what car it came from,its from an auction in japan...
TIA
8.5J 5/114.3 +38
9J 5/114.3 +45
TIA
Yes they should fit. The widest tires you should go with those wheels would be 255/35R19 front and 275/30R19 rear...that is assuming a 19" wheel as you didn't say in your post above.
Maybe you already know about this but I didn't myself until my wheels showed up on my doorstep missing a hub ring. Do the wheels you're looking at come with hub rings? If not you will want to get a set (metal not plastic). The outer measurement of the hub ring would be whatever measurement in mm the hole on the inside of the wheel is. The inner measurement would be the ISF hub size in mm...which if I remember correctly is 60.1mm. For example, my Enkei PF01s have 75mm to 60.1mm hub rings to fit the ISF.
