Low dyno pull
Old 04-14-15, 03:28 PM
TISF
TISF's Avatar
Default Low dyno pull
So today is Tuesday april 14th 73 degrees and I am at autobahn in houston's dyno jet. Doing back to back pulls with consistent 340 whp to the wheels. I have an injen intake, Ppe headers, custom true dual 2.5 inch piping to a X pipe to magnaflow mufflers exhaust, no cats, secondary cats, or resonator. And again doing 340 to the wheels, anyone else think that's a bit low..?
Old 04-14-15, 03:32 PM
TISF
TISF's Avatar
Old 04-14-15, 03:50 PM
Vervish
Vervish's Avatar
Something bad is happening at 5200 rpm...power should continue to build.
Old 04-14-15, 04:18 PM
I8ABMR
I8ABMR's Avatar
I agree. You should be putting down closer to 405 whp. The numbers you are putting down are equal or slightly less than bone stock.
Old 04-14-15, 04:25 PM
TISF
TISF's Avatar
Something bad? Anyone ever counter this?
Old 04-14-15, 05:22 PM
Vervish
Vervish's Avatar
Not sure if something is wrong, .but power does not usually drop that dramatically..
Old 04-14-15, 05:32 PM
Fsport2UR
Fsport2UR's Avatar
What gear did you dyno?
Old 04-14-15, 05:34 PM
TISF
TISF's Avatar
first run dynoed 5th last 2 in 6th
Old 04-14-15, 07:45 PM
flowrider
flowrider's Avatar
Received 1,826 Likes on 1,288 Posts
Something's definitely wrong. Here's 2 Fs (one is mine).
Mine has PPE Headers with PPE DualMode Exhaust and Hi-Flow Cats. - 392+ HP
Other one has PPE Headers, JoeZ Exhaust, No Cats. - 399+ HP
Edit - Since People are now talking intakes.
Mine has Takeda.
Other one has a K&N.
IMHO, Intakes have little impact on power. Personally I like the design of the Takeda.
Lou
Old 04-14-15, 09:23 PM
TISF
TISF's Avatar
could it be the intake? Heat soaked? The guy that dynoed said he had a F and that could've been it
Old 04-14-15, 10:34 PM
PDP180180
PDP180180's Avatar
I'd be looking at the intake if it was me.
Having lost power on a dyno with the Takeda fitted, I reverted to the stock airbox. I then fitted the HPS intake pipe and a K&N panel filter.
Second dyno visit showed a gain on both HP, and I had a much smoother AFR reading (mine spiked with the Takeda as well).
Have you still got your stock intake? If so, no harm in trying it?
Just remember you need to get a few miles under your belt before you re-dyno. The ECU needs time to re-calibrate.
Hope this helps, and you get it sorted soon mate.
Cheers.
Peter
Old 04-15-15, 03:46 AM
PDP180180
PDP180180's Avatar
Managed to find my dyno result graphs.
The red line was after I removed the Takeda and fitted the HPS intake pipe and K&N panel filter.
You'll notice gains throughout, and a smoother AFR reading as well.
Old 04-15-15, 07:16 AM
TISF
TISF's Avatar
Cheers.
Peter
Alright Il be sure to look at it, only when I look at it I see a hose not connected anyone know where that goes to ? I bought the car like this with the intake on il post a pic of what it looks like later today
Old 04-15-15, 07:20 AM
LexISguy
LexISguy's Avatar
Those numbers are stock low you should be around the 400whp mark.
Old 04-15-15, 08:33 AM
TISF
TISF's Avatar
even with the intake I feel that my headers and exhaust should still net me 370 or so
Quick Reply: Low dyno pull
