Tires
Old 03-19-15, 07:32 AM
BS ISF
BS ISF's Avatar
i ran the Pirelli corsa system 285/30/19's for over a year. they fit fine on my 08 rims. some shops just won't put oversize tires on rims that they aren't recommended for.
Old 03-19-15, 08:19 AM
flowrider
flowrider's Avatar
Received 1,828 Likes on 1,290 Posts
Originally Posted by Mish
Thanks for the responses. Can you guys let me know which tires (brands) 285's 30 19
Are guaranteed to fit on '09 stk set up and rims
Cause I live in Canada I may not be able to get or pay a ridiculous amount for.
So
so4's
Continental dw's
Thanks.
Click the link in Post #7, previous page.
Lou
Old 03-19-15, 08:31 AM
Mish
Mish's Avatar
Thanks guys. As long as 285-30-19 fit.
Just was worried about premature wear.
So will any 285 tire fit?
Old 03-19-15, 10:03 AM
VtotheJ
VtotheJ's Avatar
Yes any tire SHOULD fit, but some tires are just designed differently than others. I would recommend with the tried and true brands (for 285), such as the s04's, conti DW. If you went with Michelin PSS or PS2 I would recommend going with 275/30/19, as they are a bit larger.
Old 03-19-15, 06:41 PM
Mish
Mish's Avatar
Also I have a brand new sikky micro processor (ECU)for headers I bought for
Sale if anyone is having issues or needs one. It was sent back to sikky
Manufacturing to get tested. Turns out it was fine. I had a wire pulled in my harnass.
Thanks.
Old 03-21-15, 09:26 AM
Mish
Mish's Avatar
Hi guys. Two questions. Will 285 30 19 fit
A stk rim with this tire yokohama advance sport?
And has any used these tires before?
Thanks for your help
Old 03-21-15, 11:00 AM
UCrazyKid
UCrazyKid's Avatar
I'm running 285/30/19 on stock 2008 wheel and stock ride height (rear Lexus swaybar only) for 3 years with no problems. No perceive change in lateral hold from 275 but definite improvement in straight line traction.
I am running Vredestein Ultrac Vorti with 245F and 285R.
http://www.vredestein.com/car-tyres/...ac-vorti/info/
Here is a link to photos of the fitment: https://www.clublexus.com/forums/is-...ml#post7906001
Tires are showing even wear at 15,000 miles with stock alignment specs
Old 03-21-15, 01:12 PM
darbs242
darbs242's Avatar
Originally Posted by flowrider
^^^^You and I have differing opinions on a lot of issues. And surprisingly enough, we also agree on a lot of others.
I can attest that the 245/285 combo will fit the stock 8s and 9s and outperform the stock sizes. That's my experience, believe it or don't, your choice.
Lou
It might fit those bigger sizes but out performs is not correct. It completely depends what tire you have. I run 235/265 in toyo 888 on factory wheels and they will absolutely out perform your larger sized S-04
Old 03-21-15, 02:35 PM
Gymkata
Gymkata's Avatar
How do the R888s perform on the streets? I was considering mounting those on my 18x9.5 Enkei PF01s and runing them during the good weather months.
Old 03-21-15, 03:36 PM
flowrider
flowrider's Avatar
The Toyo Proxes R888 is a race only tire, not a street tire. They do meet DOT requirements, but you can't drive 'em in the rain and as for wear, again, a track tire. I don't see the comparison.
Lou
Old 03-21-15, 04:05 PM
lobuxracer
Tech Info Resource
lobuxracer's Avatar
Received 3,847 Likes on 2,332 Posts
Lou, you really ought to put your money where your mouth is on this one and do a track event with I8ABMR. Whoever carries higher mid-corner speed wins, because that's what wider tires are all about.
I've driven a Scion tC on 245/40/17s with 8" rims and with 8.5" rims. There is a big difference in mid-corner speed under track conditions, easily 2 mph, just as there is a 6 mph difference between a 2950 lb Scion tC on 245's with 8.5" rims and a 3415 lb MkIV Supra (yes, the Supra is slower) on OEM (235/45/17 & 255/40/17) Michelin tires.
We can always agree to disagree, but when the green flag drops, the BS stops.
Old 03-21-15, 04:57 PM
darbs242
darbs242's Avatar
Lou
Not a street tire.... Tell that to the gtr community. I drive in the rain with them all the time, not an issue.
Old 03-23-15, 05:35 AM
VtotheJ
VtotheJ's Avatar
The R888's may outperform a regular summer tire but I can't justify spending $400 more & wears out a lot faster, when the majority of my driving is on the streets.
Old 03-23-15, 06:51 AM
rmillsISF
rmillsISF's Avatar
FYI: I just put a 235/35 on the front and 275/30 Yokohama AD08 on the front (tread width is over .6" wider than the Michellin they're so square). One thing I found is the stock Bridgestone RE050 rides TERRIBLE and I never realized it was the tires doing it. The new Yoks grip like glue and cover so many more bumps while doing it... I'm loving them so far!
Old 04-01-15, 05:52 PM
Mish
Mish's Avatar
Default Headers
Hi guys. Two questions. I had headers installed and now feel a klunking noise the odd time from my front end. Car drives perfect. Usually occurs when I turn sharply. Something loose from dropping motor from frame?
Also noticed a drip of red tranny fluid on my garage floor. Drain plug? If so where is it located.
Thanks
Quick Reply: Tires
