Borla Cat Back with 4 Round Tips
Old 03-14-15, 10:34 AM
Enough
Enough's Avatar
Default Borla Cat Back with 4 Round Tips
I bought some used factory oval tips and modified them to accommodate round tips which connect directly to the Borla mufflers. Thought I would share some photos.
Old 03-14-15, 10:53 AM
ISF_GG
ISF_GG's Avatar
Looks good. Paint those screws black, and it'll look even better IMHO.
Old 03-14-15, 11:18 AM
jdm_altzza
jdm_altzza's Avatar
Looks nice digging it.. ^^ agree paint the screws black makes it look weird.
Old 03-14-15, 11:32 AM
ISFPOWER
ISFPOWER's Avatar
that looks really good. the borla seems more desirable to me if i could do something like that. any more info on what tips you used?
Old 03-14-15, 01:16 PM
Enough
Enough's Avatar
Thanks for the compliments. The tips are listed below. Bought them from Summit Racing for $26.50 each. Borla's muffler has four output stubs that are 2 inch outside diameter. I'll look into some black screws, those that are on there are stainless flange head button screws, I haven't had a lot of luck with paint adhering to stainless very long.
Brand: Vibrant Performance
Manufacturer's Part Number: 1209
Part Type: Exhaust Tips
Product Line: Vibrant Performance Exhaust Tips
Summit Racing Part Number: VPE-1209
Inlet Inside Diameter (in): 2.000 in.
Tip Shape: Round
Tip Outlet Size: 3.000 in.
Tip Quantity: Single
Tip Installation: Weld-on
Tip Material: Stainless steel
Tip Finish: Polished
Overall Length (in): 6.500 in.
Tip Cut: Slant
Tip Edge Style: Beveled edge, double-wall
Resonator: No
Old 03-14-15, 01:38 PM
chris07is
chris07is's Avatar
Wow looks great.
Old 03-14-15, 02:12 PM
joshv06
joshv06's Avatar
I like that a lot. Did you take any pictures of the installation process or whatnot? As per the screws that you used to hold that piece in place, could you not use black zip ties instead and have a more concealed look versus screws?
Old 03-14-15, 05:48 PM
Enough
Enough's Avatar
Sorry, no fabrication pictures. A lot of cardboard test templates, die grinder with a zip disc in it to mod the OEM tip/collector piece, 3 1/2 inch hole saw, aircraft nibbler tool. Requires a moderate amount of sheet metal fabrication skill.
With regard to the screws verses zip ties or other fasteners, once you have the OEM tip/collector piece in hand you can see that it is an over-designed part that is held on with a variety of strangely angled mounts.
I appreciate everyone's own cosmetic sense and feedback with regard to the screws, I will keep in mind replacing them with black ones. They are very easily replaced, I used 6mm nutserts under them, so I just need to find a non-rusting black 6mm x 20mm screw. I kind of thought the stainless screws added a little detail to the area.
Old 03-14-15, 05:56 PM
I8ABMR
I8ABMR's Avatar
looks great. Nice job
Old 03-15-15, 06:04 AM
Rickna
Rickna's Avatar
Looks great You could try getting black oxide screws or anodized.
Old 03-15-15, 11:16 AM
STLblueF
STLblueF's Avatar
Looks really good. Has anyone been able to modify a Joe-Z exhaust in a similar fashion?
Old 03-15-15, 11:34 AM
ISFPOWER
ISFPOWER's Avatar
only thing i didnt like about the joe z was that the outlet mufflers only had one tip hole. whereas the borla has two.
Old 03-15-15, 05:31 PM
Lmood
Lmood's Avatar
Looks good. Been thinking about doin this more and more for my borla. I wonder if you bought a bigger inlet diameter and fabbed up a plate with an offset hole would it look more like the iss forged.
Old 03-15-15, 06:17 PM
darbs242
darbs242's Avatar
Nice job. I do think your going to have some metal scratching noises driving around. There's a fair amount of exhaust movement on an isf.
I wish akrapovic made an exhaust for our car. They would have some insane factory integrated set up.
Old 03-15-15, 06:28 PM
BluStreak1
BluStreak1's Avatar
Very nice work! I have the same thing on my F!
Quick Reply: Borla Cat Back with 4 Round Tips
