Headlights (bulbs)
Old 03-13-15, 02:56 PM
rtwendt
rtwendt's Avatar
Default Headlights (bulbs)
I just got my 2008 ISF about 3 weeks ago and I'm looking at getting new headlight bulbs. I want to get bright white ones because I think that the blue ones I have currently look bit ricey (in my opinion). Does anyone have any suggestions as to what kind I should get?
Im also looking into new white fog light bulbs as well. Any suggestions/comments are highly appreciated!
Old 03-13-15, 02:57 PM
rominl
exclusive matchup
rominl's Avatar
if you want factory ones, they are 4100-4300k color temperature. some people get 5000-6000k ones, a bit whiter but less light output
i would also invest a bit more money on good brand ones. philips ultinion is always good
Old 03-13-15, 03:00 PM
rtwendt
rtwendt's Avatar
If I get the 5000-6000k ones, would that require any kind of additional wiring or special set up?
Old 03-13-15, 03:19 PM
Sean
Sean's Avatar
I believe any D4S will work. I went with Morimoto 5000k which I think look great. I've only had them in about 1 month though. My experience is pretty limited, but to me they seem like a good compromise between the super cheap stuff / knockoffs and the more expensive Osrams and Philips.
For the fogs, I know some people fit LEDs and HIDs into them. I just have the the 2014 LED fogs.
Old 03-13-15, 06:05 PM
PiusGS
PiusGS's Avatar
Where you get the CF on the bumper from?
Old 03-13-15, 10:33 PM
Evil Teo
Evil Teo's Avatar
get the osram CBi 5000k those are bright!~
Old 03-14-15, 06:22 AM
blckbrd
blckbrd's Avatar
I've got the Phillips Ultinon 6000k Flash White. They're a bit whiter than oe. I got them from the retrofit source here in Atlanta for right around $200.
Good luck
Old 03-14-15, 07:39 AM
4TehNguyen
4TehNguyen's Avatar
when the HID bulb went out in my 2IS, I bought an OEM phillip bulb on ebay for $40. The new one was a LOT brighter than the factory original one so I ended up getting another to match it and its much better than when it was from the factory
Old 03-14-15, 08:18 AM
streetx
streetx's Avatar
I second the osram cbi 5000k
Old 03-14-15, 08:25 AM
lobuxracer
Tech Info Resource
lobuxracer's Avatar
Received 3,845 Likes on 2,332 Posts
Same experience here. I had one bulb starting and going out after a minute or two. I replaced both on principle and got much better lighting. The bulbs were exactly the same, but their performance over time drops off, so new is always better than old.
dtLS400
10-02-11 08:46 AM
radicalrev
10-30-07 03:41 PM
andsimp2
04-25-07 07:17 AM
TouringGS
GS - 1st Gen (1993-1997)
01-30-04 01:01 PM
Tim
Performance & Maintenance
18
01-28-03 03:02 AM
Quick Reply: Headlights (bulbs)
