Question regarding 30k LSD service...
Old 02-17-15, 03:24 PM
RMA
RMA's Avatar
Default Question regarding 30k LSD service...
My car will be needing this being it has 30,300 miles currently & I plan to pick up a jug of fluid from my local Lexus dealer or order from Sewell possibly. Is it easy to change out the fluids ? Flush out the existing fluids ? I attempted doing a search but nothing came up so sorry if this has been covered in the past. Thanks
Old 02-17-15, 05:16 PM
Compthis
Compthis's Avatar
It's easy as long as you have a pump to pump in the new fluid. Make sure you can remove your fill plug and remove your drain plug. Once your diff is drained, install the drain plug and fill with new fluid until the oil spills out the fill hole. If you purchase diff fluid like motul, they come with a tube to fill your diff.
Old 02-17-15, 05:55 PM
4TehNguyen
4TehNguyen's Avatar
you can use a turkey baster too if you dont have a pump
Old 02-17-15, 06:21 PM
jat0223
jat0223's Avatar
My manual states that this service is at 60k miles. Does yours say it's at 30k miles?
Old 02-18-15, 03:02 AM
Meraki Autoworks
Your #1 Lexus Vendor
Meraki Autoworks's Avatar
I believe is it 60k miles
Old 03-22-15, 01:24 AM
allst4risf
allst4risf's Avatar
any diy for this yet?
Stemmer
RX - 1st Gen (1999-2003)
13
11-20-21 09:55 PM
airtime
09-04-11 04:01 PM
06MiCa
01-21-10 04:54 PM
klein4896
Performance & Maintenance
03-17-09 04:49 PM
akmpres
03-02-03 01:55 PM
Quick Reply: Question regarding 30k LSD service...
