Suspension advice needed...
Old 02-15-15, 11:31 AM
Stuno1
Stuno1's Avatar
Default Suspension advice needed...looks to be sagging
Hi chaps. Some advice needed. My rear left suspension is sitting just under 1.5cm's lower than rear right. Did go over a bump. Car has done 58k miles and its a 2008 model.
Is it most likely to be shock? Could it be anything else? Can't see any oil leaking at all.
Stu
Old 02-15-15, 12:01 PM
Vervish
Vervish's Avatar
Not sure a blown shock would cause it to sag. Interested in hearing from those who know.
Could it be caused by the additional weight added by the driver?
Old 02-15-15, 12:13 PM
Stuno1
Stuno1's Avatar
No one in the car when I took the measurements.
Stu
Old 02-15-15, 12:23 PM
flowrider
flowrider's Avatar
Received 1,815 Likes on 1,281 Posts
"Lexus Lean"
https://www.clublexus.com/forums/sus...t-this-is.html
Lou
Old 02-15-15, 12:42 PM
Stuno1
Stuno1's Avatar
It's the rear left that is sagging not the rear right. Just wondering what other component it may be if it's not shock.
Stu
Old 02-15-15, 01:13 PM
flowrider
flowrider's Avatar
^^^^You have a RH Drive vehicle, not a LH drive like us yanks. Also, shocks don't control the height of the car, the springs do.
Lou
Old 02-15-15, 01:21 PM
Stuno1
Stuno1's Avatar
Indeed, so would a knock effect the spring and result in the sagging? Been reading up and it does seem very unlikely it's the shock.
Is the spring the most likely culprit? If so, can you just replace one or would you need to replace both rears?
Stu
Old 02-15-15, 02:46 PM
PDP180180
PDP180180's Avatar
Stu
Just buy some coilovers already!
You know it makes sense!
Hope you get it sorted chap.
Old 02-15-15, 03:57 PM
yjk1975
yjk1975's Avatar
I think this is normal for rhd
Old 02-15-15, 09:34 PM
Stuno1
Stuno1's Avatar
By as much as 1.5 cm's??
Pete - ha no!
rmbthird
GX - 1st Gen (2004-2009)
11-08-17 05:23 AM
Chlim1122
Hybrid Technology
10-05-17 09:38 PM
jafarkhan2
GX - 2nd Gen (2010-2023)
09-21-17 01:25 PM
hieu
Suspension
11-16-14 09:32 PM
GRAYM
18
10-08-14 04:25 AM
Quick Reply: Suspension advice needed...
