"ELF" Fuel Pressure Sensor Leak *Remedy Available*
Old 05-01-15, 09:17 AM
  #211
lobuxracer
Tech Info Resource
lobuxracer's Avatar
Received 3,849 Likes on 2,334 Posts
Originally Posted by Ftech
... they are either just too lazy, or don't know the proper way of doing it.
Or they didn't watch the video or read the instructions on TIS. If they don't know the proper way, there is really no excuse. Everything they need to know is covered in TIS.
Originally Posted by TIS
All dealership associates involved in the campaign process are required to successfully complete ELearning course SC13A. To ensure that all vehicles have the repair performed correctly; technicians performing this recall repair are required to currently hold at least one of the following certifications levels:
• Certified, Senior, or Master Technician
• Certified, Senior, or Master Diagnostic Technician
So, I'm calling lazy and overconfident a big factor. I am really glad the guys doing the shoddy didn't choose aircraft maintenance. I would be afraid to fly commercial aircraft.
Old 05-05-15, 10:09 AM
  #212
ISF4life
ISF4life's Avatar
Me and my roommate just dropped off both ISF's at Lexus of Westminster to do the recall , ours good friend Pete had appointments with us today
Old 05-05-15, 10:53 AM
  #213
Compthis
Compthis's Avatar
So I dropped off the car for the work on Monday and got a call today from the service advisor. "Just calling to let you know you have a coolant leak on the rad and you will need to replace it, I'll give you a break on the price". So I said "the car is under extended warranty" he said, "let me check....um yea you are, I guess we owe you a rad". If I was on the hook, I would have requested to see the rad and make sure they didn't damage it but never the less, I'm getting a new rad. When I saw joeZ got a new rad, I was hoping something would be wrong or go wrong with mine during the work. WOOOOT!!!!!! New coolant and rad.
Old 05-05-15, 11:40 AM
  #214
digger08
digger08's Avatar
mine was also replaced last year, including the expansion tank
Digger08
Old 05-05-15, 02:50 PM
  #215
Compthis
Compthis's Avatar
Digger08
Just picked up the car and I can't complain because the work is done and I have a new rad with reservoir. The tech took picks of the valley to show me it was clear of coolant. No signs of damage anywhere and all visible harnesses are in tact. Great job Northwest.
Old 05-05-15, 03:34 PM
  #216
joshv06
joshv06's Avatar
I just dropped my '08 off at Don Valley North Lexus in Markham. I got a Service notice about the Rad Fan as well. They are going to complete both the fan (they said it's a fix based on visual) and the ELF recall. They are also going to do an oil change since its due. I showed Lexus some of the damages caused by the other dealers to the harness protector and the assistant supervisor of repairs (Arthur) told the technician to be careful. Will post an update when they tell me it's done.
Old 05-05-15, 04:54 PM
  #217
digger08
digger08's Avatar
Who was the tech?
Digger08
Old 05-05-15, 05:14 PM
  #218
Compthis
Compthis's Avatar
Who was the tech?
Digger08
Steve 10 char.
Old 05-06-15, 08:00 AM
  #219
Dubxl152
Dubxl152's Avatar
Just dropped off my '08 ISF at Lexus of San Diego to have the ELF recall done. I mentioned to my service advisor that there have been multiple instances of the engine wiring harness cover being cracked and then either being taped up, or completely removed during this recall. He assured me that he is aware of the issue, and they have the covers stocked just incase. He also mentioned that our particular engine may be prone to carbon buildup so he said he would have the tech investigate. if there is buildup Lexus will rebuild the engine free of charge i.e. pistons, rings, etc. I thought the carbon buildup issue was with the is250 only, any one else heard of this happening on a F?
Old 05-06-15, 09:44 AM
  #220
digger08
digger08's Avatar
Originally Posted by Dubxl152
J He also mentioned that our particular engine may be prone to carbon buildup so he said he would have the tech investigate. if there is buildup Lexus will rebuild the engine free of charge i.e. pistons, rings, etc. I thought the carbon buildup issue was with the is250 only, any one else heard of this happening on a F?
The service advisor is clueless about our motor and injection systems.You are correct, primarily IS250's.
Digger08
Old 05-06-15, 11:30 AM
  #221
joshv06
joshv06's Avatar
Figured I'd post an update. During the Rad Fan recall the techs found a leak in the Rad. I got lucky my '08 still has ECP so I don't have to pay for a replacement part. Guess I get to enjoy my Dodge Durango rental for another day while the part gets delivered. Crossing my fingers that everything goes okay when they remove and replace the front bumper.
Old 05-07-15, 01:32 PM
  #222
Dubxl152
Dubxl152's Avatar
Got my car back from Lexus San Diego. Car \ engine bay looks perfect and they replaced the harness cover with a new one. I drove the hell out of it on my way back to work and so far so good.
Old 05-08-15, 07:23 AM
  #223
Zelfiris
Zelfiris's Avatar
Just went on lexus.ca to check my VIN and...
093 - PEDAL MODIFICATION AND BRAKE OVERRIDE (IS 250,IS 350, IS-F)
185 - REPLACE THE INTERNAL TRUNK RELEASE LEVER (HANDLE)
189 - REPLACE THE FRONT WIPER ARM NUTS
250 - INSPECT AND REPLACE THE SCREWS SECURING THE COOLING FAN MOTORS
255 - REPLACE THE FUEL PRESSURE SENSOR GASKET (GS 300)
Edit - and my car is out of warranty
Old 05-08-15, 07:43 AM
  #224
imp0rted1
imp0rted1's Avatar
zelfiris I don't think your car has to be under warranty for those TSB's to be performed
Old 05-08-15, 07:52 AM
  #225
PatrickISF
PatrickISF's Avatar
Correct, TSB's are not warranty items. They have to be repaired whether you are under warranty or not.
Quick Reply: "ELF" Fuel Pressure Sensor Leak *Remedy Available*
