So question about brake pads
Old 02-10-15, 10:37 PM
kevintari
kevintari's Avatar
Default So question about brake pads
If my front set of Yellow Stuff ship in time for my track day but the rear set doesn't, can I track with the YS pads in the front and the nearly-new OEM pads in the rear, or will that cause a problem?
Old 02-10-15, 10:43 PM
MileHIFcar
MileHIFcar's Avatar
Let me know if you do, I'm really curious to see how the yellow stuff pads work with the 6 piston brembos on the F?
Old 02-11-15, 07:07 AM
kevintari
kevintari's Avatar
Well it looks like this won't be a problem, my $15 rear Yellow Stuff brake pads will be arriving tomorrow. Woohoo!!!
Old 02-12-15, 02:58 PM
SpeedFreaksUSA
Former Sponsor
SpeedFreaksUSA's Avatar
I see you already have things resolved but I'll give you my answer to your original question incase anyone else runs into this. The short answer is yes you can do it but its not exactly ideal. Different pad compounds obviously generate different coefficients of friction but there is much more to the story- different torque curves, ramp rates, friction rise/fall with temperature etc. Modern ABS systems are smart enough help to compensate if the variance is within reason (<10% or so) but more than that and the difference will be more apparent. The largest problem with running the OEM compound on a track will be the wear. They will wear *very* quickly if you are heating them up beyond their maximum operating temperature.
Have you used EBC Yellowstuff pads for track duty before or will this be your first time? The YS is roughly equivalent to a Ferodo DS2500 or Carbotech XP8… I think some will get away with using those but others might not on the IS-F. It will depend primarily on what tires you're using, tracks your running and of course the biggest factor, the driver. I'm curious how they end up working for you and how much they wear. Please keep us updated!
Old 02-13-15, 08:06 AM
kevintari
kevintari's Avatar
Interesting...Carbotech describes the XP8 pads as working well with open wheel (which I'm interpreting as lighter) cars. From what I've read on the YS pads, they're used with heavier cars- which is one reason I chose them. I'll report back after the 21st!
Old 02-13-15, 08:30 AM
MileHIFcar
MileHIFcar's Avatar
^^That's what I read before as well when I was using the EBC red stuff pads, it said that they work better with heavier vehicles and I'm assuming the YS pads are the same.
Old 02-13-15, 09:22 PM
SoCalISF
SoCalISF's Avatar
What were the results of the Red Stuff pads?
Old 02-14-15, 08:33 AM
MileHIFcar
MileHIFcar's Avatar
^^^I ran them on my NSX and they were great! But that car is also 800lbs lighter than the F. They were a little squeaky at times but not all the time. I never tried the yellow stuff pads that's why I'm so interested to see how they work on the F. Overall the EBC pads seem like quality street and track pads from what I've read and my own experience.
Old 02-14-15, 05:19 PM
kevintari
kevintari's Avatar
YS pads are IN, can't wait to try them out at the track next weekend!
doodlebug
11-15-17 03:28 PM
sthakor92
06-12-15 03:46 PM
fujxyooj
04-18-13 04:01 PM
Lust4Lexus
01-07-12 08:58 PM
pimplux808
Suspension and Brakes
04-24-08 12:06 AM
Quick Reply: So question about brake pads
