My F has officially broken for the first time
Old 01-25-15, 08:10 AM
darbs242
darbs242's Avatar
Default My F has officially broken for the first time
So I was lacking a car for the day and needed to go some where so I pulled the F out of the garage during winter. I was running around doing something's and my power steering light came on and my car started turning like a tank. Cycled the key and it went away. Half an hour later it quit again. Over the course of the after noon I lost and regained power steering 6 times.... Scetchy. I have an appointment at the shop that works on my car . I hope the power steering computer just needs a reset or something but who knows. Praying I don't need a steering rack.
Old 01-25-15, 08:20 AM
SoCalISF
SoCalISF's Avatar
How many miles on it now Darbs?
Old 01-25-15, 11:00 AM
kauaian
kauaian's Avatar
Was it during lower speeds? How old is your battery?
I have heard of some people experiencing loss of power steering when their battery voltage was low. I hope it's something simple like this.
Old 01-25-15, 06:06 PM
lobuxracer
Tech Info Resource
lobuxracer's Avatar
Received 3,847 Likes on 2,332 Posts
If it is the rack, the good news is you can find a any late model 2IS in the junkyard and get a "new" rack. I'm betting on the battery though.
Old 01-25-15, 07:16 PM
vbb
vbb's Avatar
Definitely keep us posted. I know that you run your car harder than most members given the tracking that you do and the mods that you have, so your car has really been a good example of what this car is capable of from a reliability even when driven hard standpoint. I bet it is just the battery.
Old 01-25-15, 08:05 PM
darbs242
darbs242's Avatar
I have just under 65000 miles. Didn't even think of a battery. But I bet that's it because I noticed the master window switch didn't operate any of the other windows which I've see the F do after a battery was pulled. Il test the battery before bringing it to the shop.
Old 02-06-15, 02:18 PM
abohler
abohler's Avatar
Did the battery fix it? I am having an issue right now where my steering on right hand turns is grinding. I am trying to figure out if it is power steering or something else.
Old 02-06-15, 02:56 PM
KSLAM
KSLAM's Avatar
My friend had a similar problem with his IS350 a couple years back. Steering took a **** on him when he was parking the car. I think its a warranty concern.
Old 02-06-15, 04:02 PM
darbs242
darbs242's Avatar
Haha... My dealer and I get along fine but one the of service writers is a member and we'll once the techs checked out my mods the warranty was no longer. but they tell stories about how they work on one of the sickest isf in the states.... They flatter me haha
Old 02-28-15, 09:35 AM
darbs242
darbs242's Avatar
So my steering problem went away after a battery charge and has come back with a C1555 Code. Motor Relay Welding Failure. Any one know causes to this code. It is causing intermittent power steering failure.
Old 02-28-15, 12:06 PM
I8ABMR
I8ABMR's Avatar
keep us posted. Hope you get it sorted. Thats the first time I have come across this code.
Mine is in the shop for the belt slip noise, sun roof rattlle, seat squeak, and oil change.
Old 02-28-15, 01:24 PM
vbb
vbb's Avatar
You may end up needing a new power steering ECU.
http://share.qclt.com/%E4%B8%B0%E7%9...em/0410010.pdf
Did you happen to do the 2012 retrofit, or are you still on your original ECU?
https://www.clublexus.com/forums/is-...it-2010-f.html
I've never heard of anyone having your issue before, nor do I have any idea how it spontaneously went bad, unless you swapped out your ECU at some point.
Old 02-28-15, 01:29 PM
darbs242
darbs242's Avatar
Naw it's original. Still on the factory 08 steering computer.
Old 02-28-15, 02:11 PM
Meraki Autoworks
Your #1 Lexus Vendor
Meraki Autoworks's Avatar
On the bright side, may be a reason to upgrade to a new steering ecu !
Old 02-28-15, 05:02 PM
lobuxracer
Tech Info Resource
lobuxracer's Avatar
Or scrap the whole rack and ECU. My car has this issue. You might imagine how pissed off I was to find this LSB long after my warranty was expired.
File Type: pdf
Quick Reply: My F has officially broken for the first time
