F final gear ratio is 2.937?
I just found out the Fj cruisers had the same size 8.2" final drive,has anyone ever tried changing the final drive?
I searched and found out the 4.2 had an early speed cut, but maybe if the ratio is not too aggressive maybe it could work?
Tech Info Resource
Looks like it is.
You might want to search a little. This subject has been addressed a few times with many thoughts about different ratios, and even a few installations.
https://www.clublexus.com/forums/is-...ff-or-not.html
https://www.clublexus.com/forums/is-...s350-diff.html
thanks lobuxracer, i am curious about this mod because i have tried a few final gear ratios with my altezza and i was happy about the results,worth the time and effort....but i will search the links you sent.
thanks
thanks
