ISF GPS issue
Old 12-19-14, 04:43 PM
rselby
rselby's Avatar
Default ISF GPS issue
I have searched and can not find what the issue is, only dead ends, had NAV out a lil while ago for screen repair, put it back in and not it is not accurate, no GPS logo under the compass on the screen, so I assume the GPS plug is not seated all the way in( this is all my search info returned) , removed and checked all the plugs and they seemed all plugged in good.....but I don't know which is the GPS antenna that I really need to be focusing on, can someone help me?
Old 12-19-14, 09:38 PM
digger08
digger08's Avatar
Pretty sure the GPS signal antennae is the one circled here.
Digger08
Old 12-20-14, 04:11 AM
rselby
rselby's Avatar
^^^^^^ Thank you..... does anyone know if the GPS antenna can stop working?
This will be my next step if the plug is seated correctly and still no GPS signal.
Old 12-20-14, 07:40 AM
digger08
digger08's Avatar
Assuming you have an DVD MAP based IS F .....did you try ejecting the CD, and reloading?
Digger08
Old 12-20-14, 08:10 AM
Rickna
Rickna's Avatar
I had a GPS ant go bad on an Eclipse (Fujitsu) unit. Same manufacturer as our units. Not likely but possible.
Old 12-20-14, 12:27 PM
rselby
rselby's Avatar
It was working fine , until the screen went bad, had it out for a few weeks for repair, when I put it back in is when all the issues with loosing GPS signal, but will try to eject the nav disc and see if this helps ( sorta re boot it )
Old 12-21-14, 11:15 AM
rselby
rselby's Avatar
ok, I have fixed the problem, it was simply came unplugged, however it is not the blue one circled above...but a grey single plug by its self, on the pic above its just barely visible at the top LH part of the pic( above and to the left of the white sticker that says U 0) plugged it is, GPS logo was under the compass and it knew where I was after just a few seconds, hope this helps someone in the future.
Old 12-21-14, 03:20 PM
digger08
digger08's Avatar
Thanks fixed the picture.
Digger08
mthorbal
10-02-18 10:23 AM
leinadmiih
SC- 1st Gen (1992-2000)
11-09-12 05:52 PM
KaiserSea1
12-28-09 05:40 PM
lexontario
09-29-08 02:37 PM
Quick Reply: ISF GPS issue
