Will these wheels fit?
I am looking for a set of new wheels since I will have to replace my tires really soon. I don't want to spend a lot of money and I been looking for a cost effective set of wheels. My car is a 2008 ISF Obsidian Black and I want to run a square setup.
I really like the Niche Targa. They are really well priced, look great but they are a little heavy. I am thinking of running a square setup but I don't know if they will fit:
http://www.vividracing.com/catalog/-...FeJF7Aod4wQAkQ
I also like the Shelvy Alcoa but I doubt they will fit:
19x10
+37mm
http://www.americanmuscle.com/shelby...=2015&model=V6
I may also try to pick up a set of stock 2015 PP wheels for cheap.
As far as tire I may run some 255 or some 265...
Thanks
Features:
Cast Aluminum 1pc. Wheel
Pattern: 5x4.5mm (5x114.3)
Offset: +35mm
Bore: 72.6mm
Silver Machined
Offset: +35mm
Bore: 72.6mm
Silver Machined
19x10
+37mm
Thanks
I been doing more research and the Avan Garde M510 looks a little better IMO but they cost around 1300 with the same specs as the Niche
Also the Renn Motorsport RS-51 are flow formed, weight about 22lbs 19x9.5 but the offset is lower +20. I don't know if that one will fit.... cost 1300 as well
No it fits fine, Heres a 19x10 +20 xxr 522 with a 275/35. Usually I get spot on with my sizing when I buy wheels/tires, maybe alil fender rollin if the car hasn't had any done before but that's better than making your suspension crappy by slamming with retarded camber that waists tires an grips terribly.
would a 19x9.5 +40 work in the front?
i pushed out my stock 2012s with a 15mm spacer so its a 19x8.5 + 30.
im on swift springs. the right tire sllghtly rubs when im going backwards with the steering wheel turned all the way to the left.
Can someone please photoshop this picture and change the color of the wheels to black and machined silver? The car on the picture has 20" wheels but I am going to get 19"s...
Thanks
Thanks
You mentioned the Avant Garde M510's but if you haven't seen them the M580's look almost identical to the Niche Targa's you first posted and were looking at:
http://www.getyourwheels.com/view-wh...e-m580-bespoke
The satin silver finish is even less for a set of 4 (I know that's not the finish you were looking for but just thought it'd be worth mentioning)
http://www.getyourwheels.com/view-wh...0-satin-silver
I been talking to GetYourWeels about the Niche Targas 19x9.5 +35 all around and they think they will not fit on the front since the IS-F has such large brake calipers.
I am thinking now on just getting spacer for the stock wheels HR5065601 25mm. Will I have any rubbing issues with the stock suspension? I plan on getting coilovers in the future.
Thanks
Thanks
