RCF air intake on isf!
was looking at some pics...looks like the RCF air intake would fit a ISF ( looks like a plastic joez ) , and the rest of the intake looks really close if not the same as an ISF, so if that car can make 467 hp with this, the ISF stock set up is really pretty good, as they didn't change it much( from what it looks)
Tech Info Resource
All new heads, different port design, all Ti valves, the list goes on and on...I am really surprised they left it the 2UR-GSE designation.
Jowett is correct according to lexus.com. About a quarter way down there's some detailed differences which makes for a good read!
http://pressroom.lexus.com/releases/...oduct+news.htm
I have an RC F unit here, it measures 84mm, it will not bolt up to the IS-F intake manifold. The holes could be filled, the pattern redrilled, and the bore ported to match. The picture shows the a 76mm t-body bored/honed to 80mm, and the stock 84mm unit. The 80mm unit gains about .10 second in the 1/4 mile on a supercharged Tundra.
Thank you I appreciate the help, I was thinking about the RCF throttle body for the ISF, what size it a tundra throttle body? And will it bolt up to an ISF? I have a ported intake manifold so I think a larger throttle body would help maximize its gains. For that matter the larger MAF might help too.
Thank you for the help!
The Tundra/Land Cruiser throttle body is the same in every way except for the location of the coolant passage.
IMO, call it a 2UR-GSE blue top. The 4A-GE had several generations which received nicknames to differentiate them... as many know, those names came from the different colors of the valve covers that each generation received.
