Vividracing Tuning/Flash
Old 11-12-14, 04:27 PM
  #61
NotnFsport
NotnFsport's Avatar
100 miles is not enough for our ecus. When a tune was tried on my F...it was similar. But at the end of the day there is not a generic flash that is going to work. Toms made a fuel controller. It basically lied to the ecu and it showed hp gaines . Problem was the ecu knew something was up and reverted back to the values before the Toms was installed. So if you guys want a tune u have to keep reflashing every 100 miles or so.....go ahead. But our ecus are very very very hard to trick.
The ecu as a cd makes me laugh everytime. Yes the engineers at Lexus put a secret map on the ISF. Its mapped for 800 hp. To access that map do the following. Up up down down left right left right B A start.
Old 11-12-14, 05:00 PM
  #62
ZaxF
ZaxF's Avatar
^haha! So you mean to tell me I can get unlimited lives and an 800 hp ISF? Do I have to blow on it before I plug it in too?
Old 11-12-14, 05:01 PM
  #63
lobuxracer
Tech Info Resource
lobuxracer's Avatar
Received 3,848 Likes on 2,333 Posts
You might ask how this TCUTuning or AutoFlash works even on a 6speed manual car. Well each unit is programmed specifically for the vehicle being used on. There are only a handful of ECU manufactures such as Bosch and Siemens. Our partners have the data for these ECU and when looking at the original mappings, they have come across something very simple. Since a ECU is made for a couple of generations of vehicles, there is code where you can access performance maps. So if you think of your ECU as a CD, right now you are on Track 1. By using the AutoFlash, it takes you to Track 3 giving you much improved torque, throttle response, and horsepower. On some cars we have seen gains of 40ft/lbs. Because this is using the factory ECU, this data does not go away, cannot be detected, and is very safe and proven on cars around the world.
This is the exact kind of BS that kills them. Every single Toyota ECM has a custom made Denso processor in it. It uses a non-standard instruction set. Saying Bosch and Siemens make them is really foolish and doesn't convince any of us who have done the homework on Toyota's ECMs. They're talking out their collective rears with this comment.
Old 11-12-14, 05:28 PM
  #64
darbs242
darbs242's Avatar
"So if you think of your ECU as a CD, right now you are on Track 1. By using the AutoFlash, it takes you to Track 3 giving you much improved torque, throttle response, and horsepower. On some cars we have seen gains of 40ft/lbs. Because this is using the factory ECU, this data does not go away, cannot be detected, and is very safe and proven on cars around the world."
When I read this I actually laughed out loud and thought to myself.... A name like vivid racing actually put this on their website. Some pretty wack stuff.
Old 11-12-14, 09:41 PM
  #65
stewb10
stewb10's Avatar
Originally Posted by Rickna
A member from the 2IS forum contacted VR and got erroneous information. And then the sales person offered it for $600.
Snake oil not included.
the sales person offered it for $500...
Then the OWNER offered it for $600
Old 11-13-14, 01:35 AM
  #66
kauaian
kauaian's Avatar
Where did you see someone get it offered for $500
Old 11-13-14, 04:31 AM
  #67
Rickna
Rickna's Avatar
Here is the post from the 2IS Forum-
Originally Posted by heyarms
I asked vivid about the gains on a 250, and if it works on boosted IS... they basically just said "huge gains! we'll give it to you for $600". i know they havent tested on a boosted car, I'm already lean in upper RPM's... theyre just salesmen it seems.
EDIT: THey just told me now it doesnt work on boosted cars. Also, theyre IS250 dyno shows WHP at 157whp AFTER the flash. Their dyno numbers are way off.... Buyer beware for sure.
Old 11-13-14, 08:43 AM
  #68
dannyk8232
dannyk8232's Avatar
For a two-player game, be sure to hit select before start.
Old 11-13-14, 08:52 AM
  #69
stewb10
stewb10's Avatar
I'm the one that talked to them. The sales guy offered $500, then when I got ahold of the owner he said $600.
Long story but I was going to use it for a 3rd party test before I put my blower back on. Vivid was far from accommodating.
Old 11-13-14, 10:08 AM
  #70
I8ABMR
I8ABMR's Avatar
Nothing has changed but the date
Old 11-13-14, 10:30 AM
  #71
streetx
streetx's Avatar
I really want to get a hold of one of these to rip it apart and see what it's actually doing
Old 11-14-14, 08:55 PM
  #72
heyarms
heyarms's Avatar
So...they posted before/after on a 250 today: before 198ft/lbs and 207whp. After 206ft/lbs and 214whp. I don't follow what they're posting... Because their other graph for an is250 (different car) said after "tuning" hit 158whp after a 16whp gain... I smell more BS. Please no one waste money on this thing
Edit: sorry thought I put this in the 2IS post about this...
Old 11-15-14, 05:59 AM
  #73
Rickna
Rickna's Avatar
I'll bet they're all the same for all the different cars listed. A couple of LED's and resistors. Nothing but a scam.
Old 11-15-14, 06:22 PM
  #74
LexISguy
LexISguy's Avatar
Another tune thread here we go again lol. All joking aside I'm interested in real life hp gains just going to wait and see what happens good luck in your attempt Vivid Racing...
Old 11-16-14, 04:14 AM
  #75
Compthis
Compthis's Avatar
This tune is so popular it's spreading like the plague, lol. It's now available on a local Toronto website. http://www.kijiji.ca/v-engines-and-e...ationFlag=true
Quick Reply: Vividracing Tuning/Flash
