question for those who have 3M blackout window trim tape
Old 10-02-14, 12:40 PM
scamsel
scamsel's Avatar
Default question for those who have 3M blackout window trim tape
for any of you that have applied this on your car.......
there is already some factory black tape that runs horizontally along the bottom of the window trim chrome, did you guys pull this off and apply the 3M or did you simply apply it over?
also, any other tips to apply?
thanks!
b
Old 10-02-14, 11:45 PM
Sean
Sean's Avatar
I applied over the black trim that is inside the chrome. The inner edge of the tape is over the black trim, however it isn't at all noticeable, especially if you lay it on straight. The only challenging part is getting it to look nice around the curve of the rear windows. You'll most likely need to do what I did and apply it in two sections, one for the top and one for the bottom, meeting in the center of the curve. There is too much of a bend in that part of the rear window trim to stretch the tape over it properly getting full coverage and avoiding any inner creases.
Also, I used the tape that Outmotoring sells for the Mini Cooper. I can't remember the actual brand, but I'm thinking if yours is 3M you may have something different that what I used.
Old 10-03-14, 04:46 AM
v8sten
v8sten's Avatar
The Outmotoring tape is 3M. You can only buy it in bulk and out motoring splits that up into shorter sections. I think you will have to get 2 of em from Outmotoring (its been a while sisnce I have done mine). I applied mine on a hot day in 1 section, I had to work it to get it to lay flat on the rear corner but it eventually did. The part that was a PITA was the very front cornerof the front windows by the rear view mirror.
To answer the OP's question I also applied it over, you cant see the seperation at all.
Old 10-03-14, 05:01 AM
Rickna
Rickna's Avatar
Looks great. It's on my to-do list.
Old 10-03-14, 06:48 AM
Lmood
Lmood's Avatar
I love mine although I will more likely peel mine off and redo it though.
Old 10-03-14, 06:57 AM
v8sten
v8sten's Avatar
same here, on my drivers side, that was the 1st side i did. the passenger side came out much better.
Old 10-03-14, 08:02 AM
Lmood
Lmood's Avatar
Old 10-03-14, 02:36 PM
scamsel
scamsel's Avatar
tahnk you guys, yeah to confirm it its the outmotoring 3m tape i got.
i guess i will apply it on the passenger side first for practice. im wondering though if i mess it up if i'll be able to pull it off without also pulling up the factory tape that is already there? guess it won't matter, but seems like it might leave gummy residue.
v8sten, car looks great, i personally think it makes the car look sooooooo much better. i like to refer to it as eyeliner, ha.
thanks for the tips guys. any up close pics would be apprecaited too! :0
Old 10-05-14, 04:49 AM
Rickna
Rickna's Avatar
Question
I see the tape is available in 2 widths, 1/2" & 5/8". Which width would be best for the ISF?
Old 10-05-14, 05:47 AM
digger08
digger08's Avatar
1/2 inch Mini Generation 1
Digger08
scamsel
scamsel's Avatar
i got the wider, gen 2 tape. when i was researching it people were saying its slightly easier to apply on our trim
Old 10-05-14, 06:05 AM
Rickna
Rickna's Avatar
So the 5/8" would give some wiggle room?
Old 10-05-14, 09:17 AM
scamsel
scamsel's Avatar
hey rick, sorry i reconfirmed, the 1/2" is the best for ours, and thats the one i got too, so gen1, sorry bout that!
Old 10-05-14, 09:30 AM
Rickna
Rickna's Avatar
No biggie. I ordered 2 pcs 1/2" & 1 pc 5/8" just to be safe.
Old 10-05-14, 09:07 PM
jt321
jt321's Avatar
Did you guys get glossy or matte?
Quick Reply: question for those who have 3M blackout window trim tape
