Power for Sub Amp
Old 09-09-14, 10:08 AM
Rickna
Rickna's Avatar
Question Power for Sub Amp
I'm putting together a sub woofer system and I could use some pros & cons on running a power cable to the trunk. As I see it I have 2 choices under the car or through the cabin.
My other concern is that when I remove the battery how will that affect the ML system. I assume I'll lose presets, etc. I don't know if it will be disabled.
I appreciate your input.
Old 09-09-14, 03:04 PM
rselby
rselby's Avatar
I ran mine through the cabin, I didn't have to remove battery, just cut a small slice in the grommet behind the batt and push it through to cabin.
Old 09-09-14, 06:03 PM
jlam86
jlam86's Avatar
^ did the same thing =)
Old 09-09-14, 06:57 PM
Rickna
Rickna's Avatar
Thanks-That settles it. Through the cabin it goes.
But, do you know if disconnecting the battery will disable the ML/Nav system?
Old 09-09-14, 07:10 PM
rselby
rselby's Avatar
no, it shouldn't really bother it, may loose your radio station preset's and have to reset clock.
Old 09-09-14, 07:35 PM
Rickna
Rickna's Avatar
Cool-Thanx again.
Old 09-10-14, 06:03 AM
MisterSkiz
MisterSkiz's Avatar
And I believe your windows and sunroof will have to be recalibrated too..
Old 09-11-14, 04:11 AM
Rickna
Rickna's Avatar
Dang! Removing the battery would give me alot of room. I have other cables to route for laser shifters. Oh well, I'll just have to work around it.
Thanks...
Old 09-11-14, 08:15 AM
Sean
Sean's Avatar
What is this recalibrating windows and sunroof? I had my battery disconnected and didn't have any issues with either.
Also, it may vary depending on different versions of the NAV, but for my 2010 I lost my radio station, Nav, and seating positon presets, but other settings, such as treble, bass, and bluetooth, remained.
Old 09-11-14, 03:36 PM
Rickna
Rickna's Avatar
Now, this makes more sense...
jaywuzhere
RC - 1st Gen (2015-present)
08-06-16 01:44 PM
sarantis
03-09-14 07:32 PM
nlimit19
12-24-13 09:06 PM
rj4510
08-10-13 09:36 PM
liv2spd
11-30-09 07:51 PM
Quick Reply: Power for Sub Amp
