Traction control turning it's self on after being turned off???
Old 09-04-14, 10:31 PM
Stuno1
Stuno1's Avatar
Default Traction control turning it's self on after being turned off???
This is probably me being a muppet but worth an ask. I was driving the over day and turned off traction control. Light comes on the dash and then within 5 mins the light on the dash is off again. Did this 2 or three times. Any ideas?
Stu
Old 09-05-14, 04:12 AM
LexusISF19
LexusISF19's Avatar
When i first got my IsF i was wondering same thing. I think its a safety reason. For full traction off and to stay on press and hold the button for 5eeconds
Old 09-05-14, 04:28 AM
Stuno1
Stuno1's Avatar
Oh ok! Assume the warning light stays on that way?
Stu
Old 09-05-14, 05:20 AM
Defratos
Defratos's Avatar
if you press and hold down the traction control button for several seconds it should stay off until you switch of the car or push the button again.
Traction control light and warning lights come on and stay on.
Be careful when you turn off traction control fully, if there's any rain or sand on the ground be prepared for a 360 if you're not pointing the car straight
and awesome choice of car, especially in the UK, I think I've only seen 2 or 3 ISFs in my 21 years living in the UK
Old 09-05-14, 05:30 AM
ISFalex
ISFalex's Avatar
Or do the pedal dance
Old 09-05-14, 06:43 AM
VtotheJ
VtotheJ's Avatar
You're supposed to come to a full stop and then hold the trac button down for at least 5 seconds. VSC and Trac will then be turned off......+1 on what Defratos said, be careful.
Old 09-05-14, 06:56 AM
Stuno1
Stuno1's Avatar
Cheers. Quite a few active owners on the uk lexus forum. Love the rarity
Old 09-05-14, 07:25 AM
Compthis
Compthis's Avatar
The ISF is 7 years old so I think you'd have a hard time seeing one 21 years ago
Old 09-05-14, 07:31 AM
boostftw
boostftw's Avatar
yep
Old 09-05-14, 08:19 AM
Evil Teo
Evil Teo's Avatar
traction control doesn't fully turn off with the button held down. u need to do the pedal dance to fully have it off 100%.
Old 09-05-14, 08:31 AM
lobuxracer
Tech Info Resource
lobuxracer's Avatar
Received 3,838 Likes on 2,327 Posts
Originally Posted by boostftw
yep
Bad idea. The pedal dance takes away the electronic LSD. Even with the OEM torsen, the eLSD is a great idea because a Torsen acts just like an open diff if you lift a wheel. I've proved this beyond all doubt at the track. Never will do the pedal dance again, the car is way better with just a press and hold to shut off VSC while in Sport mode.
Old 09-05-14, 08:58 AM
Compthis
Compthis's Avatar
So you're saying a 2008 with the 2010 diff has an advantage over the 2010 model year due to the ELSD? I track my car but I'm not seasoned enough to feel the difference between having ELSD off/on.
Old 09-05-14, 10:09 AM
Defratos
Defratos's Avatar
cheeky b@stard lol
What I meant is whenever I'm in the UK I rarely see an ISF....better
Old 09-05-14, 10:24 AM
lobuxracer
Tech Info Resource
lobuxracer's Avatar
The eLSD never went away. It's still there unless you do the pedal dance, and wisely so.
Turn 8, CMP on track out with pedal dance, the engine revved to the limiter like I had a bad clutch until the rear wheel came back on the ground. I'll never run without the eLSD again, and as I said above, even with a Torsen, if you lift a rear wheel as I did exiting turn 8, your engine will hit the limiter unless you have the eLSD working. This is also why I think the stock front springs are inadequate for track driving. The rear wheel shouldn't come off the ground in the first place and wouldn't if the front springs were up to the task.
Old 09-05-14, 01:07 PM
Compthis
Compthis's Avatar
cheeky b@stard lol
Better!
Quick Reply: Traction control turning it's self on after being turned off???
