Suspension experts
Suspension experts
Hey guys, I am looking for some advice on suspension setups that will get rid of this wheel gap. I know some people prefer springs, some coils, but what SPECIFIC setup whether coils or springs would eliminate this gap without running into issues with rubbing. I can roll the rear if necessary, I don't want to pull anything or get new tires. The car won't ever be tracked. Post pics of your setup if you have the same wheel specs so I can gauge what the drop will be on these specific tire and wheel sizes. Thanks!!!
Wheel and tire specs:
20x9 +32 245/30/20
20x10.5 +45 285/25/20
20x9 +32 245/30/20
To be honest, I've never purchased coilovers, only springs, so I am unfamiliar with the spring rates and adjustability and all the other variables that come into play with coilovers. I just installed an Eibach Pro Kit on my wifes car after some feedback on the G37 forums from someone who ran the exact setup her car has and her ride height is perfect.
If you're solely looking for a drop, then Tein or Swift springs would suffice. Both drop it 1" front and .6" rear. But for adjustability and a a more performance-oriented approach, I'd go with coilovers.
Tech Info Resource
The Maker
All shocks require rebuild when they are worn out, and most coilovers on the low end just replace complete cartridges vs rebuilding. If sprung properly coilovers can last a long time because there is less work in the fluid and therfore less heat and pressure to break down the seals. Swift Sport springs would likely be the best choice for your needs if you are not planning on doing anything else in the future.
Mike
Mike
__________________
Redefining Lexus Aftermarket Parts Since 2001
-- We are your Lexus suspension experts--
BCR - KW - PENSKE - OHLINS - HKS - GREDDY - STANCEPARTS
Links - Arms - SuperPro Poly Bushings - Solid Bearing Conversions - Motor Mounts
RB BBK's and 2P Rotors, G-Loc pads, Radium Fuel Systems
Custom Fabrication Design and Machining - Industrial 3D Printing - Laser Cutting
2018 USTCC Sportsman Class Champions - 2018 NASA ST5 National Champions
MisterSkiz- I don't think there's a specific amount of miles driven. Stress on the coilovers from driving conditions will dictate how long they last. If you hear any noises or see any oil leaking when inspecting them from time to time, it's time to rebuild. You do have to factor in shipping costs and wait time, so there will be some downtime when having the manufacturer rebuilding. A few of my friends who've needed to rebuild their Tein coilovers said that there was a considerable amount of wait time (upwards of four months), so it might not be worth it to some.
Pretty sure that the drop with swift springs will fix your issue. I think we have member here with a drop and the same wheels and tires with no rubbing. Ask to confirm but if you want to keep it simple you can just do Swift springs and you should have no issue. Coil overs are always recommended over springs but if your after cosmetics and your not tracking the car I think you should be fine with just springs. There are many good reviews and comments ere on Swift springs
You guys are awesome!!!! Thanks for all the responses. Anyone know who the member is with the similar setup and swift springs? I have been sifting through the search menu trying to find it. I think I may go the spring route if it lowers it significantly enough to reduce the wheel gap. It's a pretty big gap in the front, the rear isn't too bad honestly but I would like to reduce it without rubbing if possible I really don't feel like dealing with the hassle of rebuilding the coil overs to be honest, I daily drive my car and can't afford the down time.
Found a quote from a member running a very similar setup in an old thread, he hasn't been active for months so maybe someone here can chime in.
I am running:
20x9 +32 245/30/20
I am curious if I roll my rear fenders with my tire and wheel setup if I will experience rubbing. I am running 2mm less aggressive offset then him in the rear. The front offsets are 3mm more aggressive on mine, but the tires are a 30 series instead of a 35 like he's running. He said he was going to try a 285/25/20 next on his, but he hasn't been active so I don't know if he ended up doing it. My tire is 0.89 inches less overall diameter and .44 inches less sidewall height and 2mm less offset in the rear. In the front I'm 0.96 inches less overall diameter and 0.48 inches less on the sidewall height, but 3mm more aggressive on the offsets. What do you guys think?
I am running:
20x9 +32 245/30/20
