Help - rear shock?
Old 08-17-14, 11:32 AM
szhark
Registered User
szhark's Avatar
Default Help - rear shock?
Hey guys.. so i woke up to my car this am and noticed the back right shock seems to have deflated? lowering the back right wheel well to within an inch, raising the front right fender to about 4 inches.
Can anyone tell me what the heck could have happened? is this safe to drive to the shop? There's no rubbing, but it's really close. Can i fix this myself?
Thanks in advance..
rear right wheel
front right wheel
left side of the car
rear right shock
Old 08-17-14, 11:51 AM
yjk1975
yjk1975's Avatar
Is it under warranty?
Yes, take it to the dealer.
No, time for some coil overs or buy the shock and replace it.
Yes it's ok to drive it to the dealer or shop.
Old 08-17-14, 01:34 PM
bnizzle87
bnizzle87's Avatar
Yeah, you're still fine to take it to the shop or dealer. If it's out of warranty, I would go with coilovers, as yjk1975 mentioned. It will cost probably just as much to replace the shock at the dealer with labor as getting new coilovers. Be safe and take precaution driving to the dealer. And if you're decided on getting coilovers, there are some great forum vendors who sell them for forum pricing, so inquire with those distributors. Best of luck, my friend!
Old 08-17-14, 07:28 PM
szhark
Registered User
szhark's Avatar
Thanks friends.. checking my options and i'm thinking it might be time to upgrade.. your input has been much appreciated.
-sz
Old 08-18-14, 12:36 AM
ISFpat
ISFpat's Avatar
Shocks do not dictate ride height.. springs do. The shock can not hold up the weight of the car. Just an FYI.
Old 08-18-14, 07:47 AM
scamsel
scamsel's Avatar
what the heck would have caused this?
Old 08-18-14, 08:07 AM
yjk1975
yjk1975's Avatar
Maybe the perch the spring sits on broke off.
Old 08-18-14, 10:39 PM
lobuxracer
Tech Info Resource
lobuxracer's Avatar
Received 3,842 Likes on 2,330 Posts
The pressure in the shocks does affect ride height. The thing to look for is fluid leakage at the rod/body interface.
Old 08-19-14, 08:15 AM
tgui
tgui's Avatar
Yup, those suckers are under pressure. Never toss one in a fire, shoot it, or puncture by other means.
Old 08-19-14, 08:50 PM
lobuxracer
Tech Info Resource
lobuxracer's Avatar
The factory service manual actually says to drill a hole in it before discarding to discharge the gas safely. It also says to be certain to wear eye protection when you do this as metal chips are going to be flying around at high rates of speed when you break through.
mbarron37
04-09-23 09:31 AM
Mbutler132
06-25-19 01:09 PM
Conor09ES
ES - 5th Gen (2007-2012)
17
03-08-18 07:11 AM
Belement
Suspension and Brakes
02-12-08 05:43 PM
Quick Reply: Help - rear shock?
