DIY: Fitting stock exhaust inside a second gen IS
Once a year I have to get my car inspected and with that comes the exhaust swap back to stock. Have seen a few reports here that the stock exhaust does NOT fit in the trunk and/or cabin so I wanted to share with you all that it is possible and not all that hard. Note: All exhaust pieces were placed inside through the front passenger door.
Step 1
Remove the headrest from the passenger seat and slide the seat all the way forward and tilt all the way back. Cover the area with towels, drop cloths, blankets or something.
Step 2
Cover the exhaust pieces to protect the inside of the car.
Step 3
Place muffler section inside the car. Note the side with shorter piping to the muffler goes in first. This will allow the exhaust to fit in behind the driver seat.
Step 4
Place the mid-pipe section in next with the dual pipes going inside the car first. Rest the dual pipe pieces on top of the backseat and the resonator rested up against the glove box.
Step 5
Drive safely. You wouldn't want to be in an accident with these pieces flying around!
Step 1
Step 2
Step 3
Step 4
Step 5
I would say just watch out for that midpipe under moderate to heavy braking. There is protection on both ends, but I'd be afraid of it coming in contact with the rear windshield. I've seen that happen, not on an IS F but on another car that needed to house the stock exhaust.
lol in my state of TX you dosent need to removed anything if your car dose have check engine light pop on then you will fail but could be fix that issue is that paying them extra other word under table money they will normally make it go thru but you much be know them for long time or they know you well in order to do that (>^~^<)
PS.
I'm sure you remember how traffic was here in the DC area when you lived out this way.
Tech Info Resource
h4x0rz FTMFW! Nice work and thanks for sharing!
CaymanDive, my IS-F with a JOE-Z exhaust (with high flow cats that were on the exhaust when I got it) and Sikky headers, and I pass VA emissions and inspection. Why do you put the stock exhaust back on? Do you not pass?
Anyway, swapping the exhaust isn't all that bad. It costs me about $200 to do the swap and it's a good time to get my yearly oil change done and things checked out. (Don't drive it very often) This year during the exhaust swap we noticed the water pump leaking and with just a week left in warranty I got lucky!
