Spacer quick question
Old 07-22-14, 12:27 AM
shahir18
shahir18's Avatar
Originally Posted by LexusISF19
you got pictures ?
https://www.clublexus.com/forums/8634165-post1629.html
Old 07-22-14, 06:05 AM
jackhui
jackhui's Avatar
i'm running 15mm all around on my 2008 with OEM wheels.
I can't remember if the OEM studs were protruding out a bit or not but my wheels sit flush.
so most likely there are receding holes at the back to accommodate the oem studs.
this is the only pic i have available at the moment that shows the wheels. you can see the back is pretty flush with the body. the front is the same if the wheel wasn't turned.
Old 07-22-14, 08:46 AM
LexusISF19
LexusISF19's Avatar
Originally Posted by jackhui
i'm running 15mm all around on my 2008 with OEM wheels. I can't remember if the OEM studs were protruding out a bit or not but my wheels sit flush. so most likely there are receding holes at the back to accommodate the oem studs. this is the only pic i have available at the moment that shows the wheels. you can see the back is pretty flush with the body. the front is the same if the wheel wasn't turned.
what spacers u use ?
Old 07-23-14, 10:15 AM
speeddem0n
speeddem0n's Avatar
I noticed my car has spacers on the front when i bought it but havent pulled off the wheels yet to see what size, will update when i do.
Old 07-23-14, 10:40 AM
I8ABMR
I8ABMR's Avatar
Pretty sure it the same part number for the IS350. I am seriously thinking of getting spacers too. Most seem to have no issue but I did find a thread with someone having vibrations with them but he did have a **** load of other suspension mods and aftermarket wheels
Old 07-23-14, 10:55 AM
jackhui
jackhui's Avatar
I got the spacers from B2 Auto design. they are a sponsored vendor here on CL
look them up. i haven't had any problems since i've got them and that was 5 months ago.
Old 07-23-14, 12:18 PM
shahir18
shahir18's Avatar
Swift Springs on Front Only w/15mm Spacers all around - Stock Tire Specs (225/40 & 255/35)
Old 07-23-14, 01:54 PM
jackhui
jackhui's Avatar
^^ i have the exact same setup . other than i have Tein springs. but only front lowered with 15mm all around on OEM tires.
looks good =)
Old 07-24-14, 09:03 AM
LexusISF19
LexusISF19's Avatar
^^ i have the exact same setup . other than i have Tein springs. but only front lowered with 15mm all around on OEM tires. looks good =)
anyone have swift springs all around with 15mm spAcers and the 245/35 and 275/30 setup?!?
Old 07-24-14, 12:15 PM
H60Driver
H60Driver's Avatar
Yup. I do. Perfect fit. No fender trimming and no rubbing.
Old 07-24-14, 12:21 PM
shahir18
shahir18's Avatar
^ for the 12+ it would be slightly different, since the wheels are wider... I do plan to get 245/275 combo, but hope I will not have any rubbing issues
Old 07-24-14, 02:19 PM
jackhui
jackhui's Avatar
my OEM tire size, i do rub on the passenger front fender liner when i turn at a specific angle.
the vents in the liner makes noise when i'm reversing at a turn angle. but nothing major.
Old 07-24-14, 02:31 PM
shahir18
shahir18's Avatar
lol, mine does the same in the passenger front while I reverse at a turn angle
Old 07-24-14, 03:20 PM
BlackISFtx
BlackISFtx's Avatar
I got the B2 auto design 15mm spacers on the stock wheels. No rubbing or any issues. No extended studs needed!
Old 07-24-14, 03:37 PM
BlackISFtx
BlackISFtx's Avatar
looking sweet!
Quick Reply: Spacer quick question
