Cheaper LED fog lights replacement! Good for budget
#47
#49
I guess it's fine with the LEDs as they don't produce as much heat. But i have seen them make a burn marks on the hottest spot on the lens.
I like the 3000k color but prefer the clear lens.
arg, where's my lights ??? can't wait lol . stupid Canadian custom's taking a long time to clear it...
#50
I have yellow laminx on mine and when I swapped the bulbs to jet yellow putcos burn marks happened. I figure it'll be a lot of trouble to get that stuff off so I'm thinking about these lights now, but also wish there color options aside from just laminx.
#55
Threw a pair of these in last night. Still need to adjust them. But noticed that if you slide the inner tabs into the existing slots, there's a slight gap to the fog light plastic cover. Now I can't find the thread, but remembered someone saying you can place the tabs in front of the slots which flushes up the glass. However, I am wondering if this will make adjusting them upward more difficult. I ran out of time last night to mess with them, but will be doing a clear lens swap this weekend so will have everything apart anyway.
Just curious if anyone went the route that I did, and if they had any issues adjusting them upward. Right now they are basically pointed at the floor haha. Color looks sweet though they are useless at the moment.
#56
1st pic is difference between stock and the Morimoto LED.
2nd is closeup of fitment.
3rd is post-install.
4th is headlights only beam pattern.
5th is with fogs on. This was before I adjusted the passenger side up a little bit and now they are even.
#60
Bump. I am ordering a set of Morimotos.. Can anyone recommend a replacement bulb for the highbeams/DRL? I'm looking for more output and color matching would be a bonus. The same site offers the OSRAM 9500 but i can't find any references to the color temp.
