ISF w/o Bluetooth music streaming - I got rid of my engine whine
Hey guys,
I bought my 09 ISF about 2 weeks ago and was quite upset when i realized it didnt have bluetooth music streaming as I listen to music all the time while driving. I know it quite easy to plug in the AUX, but I much rather not have to do that either and have a cleaner look inside the car.
I initially bought the BlackBerry ACC-41596-001 Music Gateway (
I had whining noise, which i didn't hear during music play as I listen to music quite loud, but definitely annoyed the crap out of me in between the songs or when paused with volume on stereo still up.
I had decided to return it but then did more research online and came across members using a ground Loop Noise Isolator (
I figured i give it a shot for $12.00. So just installed it a little while ago and to my surprise, I had no engine whine at all. Even pushed the car towards redline, but i didn't experience any engine whine.
So finally had a solution to the one thing that annoyed me. Now the music gateway automatically turns out when I start up the car and automatically connects. No need to push any buttons every time you get in.
THE ONE DRAWBACK i have noticed - the noise isolator while removing the engine whine has caused a little drop in volume in bass. Now instead of listening to it at about 45-50 I am listening to it around 55-60, which is fine for me but figure i point it out for others. Also i typically had my bass in negative, but now pushed it up higher as well. By tweaking the audio settings a bit, I am back at where i was before.
I figured i'll put the info out there for anyone else that may want to try it. If this post makes no difference in your life, then just ignore. No need for unnecessary comments.
Disclaimer: while this worked for me, it may not work for you. Spend money at your own risk. lol
Alright, my essay is over. Peace out
Amazon.com: BlackBerry ACC-41596-001 Music Gateway - Retail Packaging - Black: Cell Phones & Accessories
) as well as the oem charger thinking i shouldn't have any issues using oem parts. WRONGI had whining noise, which i didn't hear during music play as I listen to music quite loud, but definitely annoyed the crap out of me in between the songs or when paused with volume on stereo still up.
Amazon.com: PAC SNI-1/3.5 3.5-mm Ground Loop Noise Isolator Works with iPod/Zune/iRiver and Others: Automotive
).I figured i give it a shot for $12.00. So just installed it a little while ago and to my surprise, I had no engine whine at all. Even pushed the car towards redline, but i didn't experience any engine whine.
^^^^^ This....must be a weak ground causing a loop problem.
Also, 55-60? WOW! Radio in mine is pretty loud around 25, and mp3/cd around 256k is loud around 30. And this is the first car I haven't rigged amps/subs
When it comes to anything audio, Ipod adapters etc a lot of folk on here use these guys...
http://www.vaistech.com/site/home.php
I just ordered an ipod adapter for my 2009, still have to have it installed though.
Tech Info Resource
I'm not sure if your '09 has a USB port that you could use and then add a 30 pin blue-tooth adapter to stream audio. I'm not sure if this will work but this is something like is worth trying. http://www.ebay.com/itm/Bluetooth-Music-Audio-Receiver-Adapter-For-iPod-iPhone-30-Pin-Dock-Speaker-BK-/390877641034?pt=US_USB_Bluetooth_Adapters_Dongles&hash=item5b021f794a On my wife's MB I ordered this for her and it works with no problem and gets power from the 30 pin connection. http://www.ebay.com/itm/ViseeO-Tune2air-WMA1000-Champagne-Color-for-Apple-Samsung-North-America-Warranty-/141285723905?pt=US_Mounts_Holders&hash=item20e5490f01
http://is.sewellparts.com/accessorie...2008/5403.html
Tech Info Resource
The fix is a high pass capacitor in a fancy box. The may have an inductor in there too if bass level is impacted.
The real solution is to isolate audio ground from car ground. There are a lot of ways you can do this, even with the Gen5 nav/audio.
Hey guys,
I initially bought the BlackBerry ACC-41596-001 Music Gateway (Amazon.com: BlackBerry ACC-41596-001 Music Gateway - Retail Packaging - Black: Cell Phones & Accessories) as well as the oem charger thinking i shouldn't have any issues using oem parts. WRONG
I had decided to return it but then did more research online and came across members using a ground Loop Noise Isolator (Amazon.com: PAC SNI-1/3.5 3.5-mm Ground Loop Noise Isolator Works with iPod/Zune/iRiver and Others: Automotive).
