Nickel Spark Plugs?
Old 06-06-14, 08:48 AM
abohler
abohler's Avatar
Default Nickel Spark Plugs?
Anyone know of a set of nickel spark plugs for the ISF?
Old 06-06-14, 09:35 AM
kauaian
kauaian's Avatar
No and why?
Old 06-06-14, 10:10 AM
abohler
abohler's Avatar
Originally Posted by kauaian
No and why?
Running 100 pills. Want nickel to run cooler and avoid detonation. Trying to turn up power to 150-175 shot.
Old 06-06-14, 11:52 PM
hamooduae
hamooduae's Avatar
i would love to know more about PLUGS
or a site to buy them from
once a guy told me he ordered a garage to make for him , for isf
and that it made big different at the acceleration
if you have info provide us bro
Old 06-07-14, 05:30 PM
shyguyF
shyguyF's Avatar
I don't think every members here use different spark plugs but the OEM. Only me is running Denso IKH20 iridium power plugs, to me it works perfectly and very smooth for daily drive.
You can check this Denso K20HR-U11, it is a nickel and has the same specs like stock ones
Thread size 14mm
Hex size 16mm (5/8")
Reach 26.5mm (1.04")
Gap 1.1mm (0.44")
Heat Range 20
Hope this help buddy.
Old 06-09-14, 09:11 AM
abohler
abohler's Avatar
Thread size 14mm
Gap 1.1mm (0.44")
Heat Range 20
Awesome. Thanks, I'll check those out.
Old 06-09-14, 12:29 PM
s4chico
s4chico's Avatar
I used to run silverstone spark plugs in some of my forced induction cars in the past and they worked great from what I can remember. They have a silver electrode instead of copper or iridium. They are made by Nology....maybe you can check them out and if you decide to try them....definitely let us know how they work. Funny..... I forgot all about those until I saw this thread. lol
Old 06-09-14, 12:50 PM
v8sten
v8sten's Avatar
the general rule on heat ranges is 1 step colder for every 100hp nitrous shot. stay away from iridium plugs. i personally ran NGK plugs in my race cars and some of my daily drivers. if i ever spray my ISF I will run NGK plugs in it. Now they will not last as long as iridium but will perform much better. you may notice a little harder start and it may run a little rougher with "nitrous plugs" in it but when you activate the kit, it will run like a scalded ape.
If things were to go bad, like a fuel solenoid sticking the NGK plugs (non iridium) will melt the plug and kill that hole before it damages anything else.
People have run iridium plugs with luck using the same concept, 1 step colder for every 100 hp. but if things go wrong like the fuel solenoid sticking closed, the iridium plug can take that abuse. so that will lead to the next weak spot. Either flame the head or flame the piston.
shyguyF
IS F (2008-2014)
10-07-12 06:20 PM
southtrian
Maintenance
04-13-06 11:05 AM
Jimbo2828
Performance & Maintenance
06-11-05 04:26 PM
indypwr
GS - 1st Gen (1993-1997)
12-17-02 08:19 PM
ShowGSLuVv
05-11-02 12:42 PM
Quick Reply: Nickel Spark Plugs?
