2013 Headlights
2013 Headlights
Need everyone's help on this issue.
I recently bought some used 2013 headlights off a member on this forum. Upon recieving the headlights, the box was pretty much open from how it was handled/damaged during shipping. I failed to carefully inspect the headlights when they arrived as I knew I had no idea how to install them. Last night, I was prepping them to take them to my local installer when I noticed a piece of plastic inside the box had broken off from one of the lights. I quickly found that the same exact piece broke off the other side however only 1 broken piece was recovered. The other broken piece must have slipped out the box during shipping. To top things all off, I also noticed a minor crack/chip on the top corner of a headlight. Luckily, the seller included $1k worth of insurance although it wouldn't cover my purchase price. With this being said, for those of you who have this MY year light installed:
1) Would I still be able to install the lamps without the clips pictured below? The areas circled in red depict where the clips broke off from and the white circles show where I believe they should be screwed on which still are intact.
2) If not, what do you all recommend? File an insurance claim with USPS although I would end up losing money since the lights were insured for less than my purchase price? If I filed a claim, would they reimburse me and possibly let me keep the lights since they were negligent with my package during shipping?
For the record I am not blaming the seller for any of this happening. He did what he could to try to avoid this from occuring. Is labeling the box with 'FRAGILE' all over it not enough?
Feel free to chime in with any suggestions. Thanks
Please clarify your response a tad bit MK4Sup_isF. The piece that broke off seems to be part of the back cover of the headlight. Doesn't appear to be removeable or replaceable unless the lamps were baked.
Your #1 Lexus Vendor
I bought some crappy used broken 2011 headlights off the forums with missing tabs everywhere, just superglue the tabs that you have back on. I went to tommy at music box and he took care of everything for me.
__________________
Your #1 Dealer for Aftermarket Performance Products
Orange County, CA
Text/Call: 213 394 2886
Orange County, CA
Here is a link to Sewell's diagram showing the replacement tab part numbers.
http://is.sewellparts.com/images/oem...000/814491.jpg
The broken tab can be cut off from the headlight. I used a loose hack saw blade and carefully removed one in the past. Once removed, the replacement tab can be screwed onto the headlight. It's a little nerve racking, but if you take your time, you'll be fine and the light will be as good as new.
What exactly did Tommy do for you and how did he charge? I can super glue one of the tabs but the other one is missing somewhere. Will mounting the headlamps as is cause any issues?
Thanks for the heads up. Didn't know this was even possible. Will the mounting the headlamps w/o those tabs cause any issues?
Im located near DTLA but will most likely be installing with Tommy. The lights already came pre-wired to be on as long as the car is on as well as intermittently blink with the turn signals such as the late model Audis. Since you seem to know a lot about the headlights, do you know if the headlights will fit on a 08 ISF if the cap is placed under the LED board? The previous owner mounted without the cap and instead sealed the hole with 3M film. Please advise.
The headlights can be mounted without the tabs in place, but the top corner of the headlight will stick up a few millimeters and not sit perfectly flush with the body of the car. No one would probably notice unless they were looking up close, but if you are OCD like me, you will want to fix it so you have perfect fitment.
