Anybody care to explain how PPE and Sikky "O2" conditioners work?
Old 05-16-14, 05:23 PM
ToothDoc
11 Second Club
ToothDoc's Avatar
I'm not sure if that would trigger a CEL or not. There is another kind that is an extension like those with a small catalytic converter inside so the secondary O2 actually sees a cat but the rest of the exhaust doens't. In the end, there is more than one way to skin a cat and as long as inspections go fine and I gain the HP, I really dont' mind any solution. I just started thinking about this in light of the CEL I've had recently.
Old 05-21-14, 02:39 PM
imp0rted1
imp0rted1's Avatar
doc
not sure if you saw the usdm novel header thread.. look at the o2 adapters
90 degree "mechanical fix' type.. also has holes for exhaust restriction.
maybe this is key to success...
Old 05-21-14, 04:29 PM
Juanca
Juanca's Avatar
Lou, I witnessed this race and didn't expect CJ to be so close to Danny. Even though Danny was ahead, he was just walking away, not pulling as hard as I thought for full exhaust plus headers and no cats at all.
Originally Posted by lowrideraz
^^^^I asked the same question in another thread:
I took his explanation with a BIG grain of salt.
Lou
Old 05-21-14, 04:31 PM
Cronic
Cronic's Avatar
Originally Posted by imp0rted1
doc
I would have to imagine PPE or SIKKY would have tested/explored mechanical fixes first, before going the way of the elec. fix. I mean those mechanical fixes have been used on cars for a LONG time.
Old 05-21-14, 05:44 PM
RCB
RCB's Avatar
^^^^ I am thinking that the A/F sensor only reading off the back cylinders vs. PPE/Sikky collecting the sum of each bank might have something to do with why novel can use this method.
Old 05-21-14, 05:56 PM
Cronic
Cronic's Avatar
Can you expand on that? I can't see how that would effect the rear o2/cat efficiency, but maybe it does.
One thing I can see is how many people(on usdm cars) are actually running Novel headers, and for how long? Who knows if the fix will even work, long term.
Old 05-21-14, 06:12 PM
RCB
RCB's Avatar
I really don't have a technical explanation. I just see that as the only thing that is differant. Good point about the length of time being used. Maybe it is an assumption that the mechanical fix will work on U.S. cars.
The only other thing I can think of is that maybe the rear cylinder only sampling causes the A/F sensor to see a richer mixture. That might make the ECU lean the mixture out a little which would help get the sample for the rear sensor (which is also pulled away from the exhaust stream)where it needs to be.
That's assuming that the intake manifold design favors the forward cylinders and even at that my idea is a huge stretch. I am really not even subscribing to that theory but more or less just thinking out loud.
Old 05-22-14, 02:24 PM
imp0rted1
imp0rted1's Avatar
found this on ebay
http://www.ebay.com/itm/O2-Sensor-Bung-90-degree-Catalytic-Converter-NEW-/151275647594?_trksid=p2054897.l4275
listed as "precious metal substrate" so i'm assuming that means the honeycomb is actually a mini cat?
Old 05-22-14, 08:21 PM
RCB
RCB's Avatar
That would make more sense then it just being an elbow that moves the sensor out of the exhaust flow.
eaglclon12
IS F (2008-2014)
13
08-25-17 08:04 PM
MDHLexus
Performance
08-15-16 11:19 PM
Rider
IS F (2008-2014)
01-14-15 10:13 AM
x2jzsc300x
Performance & Maintenance
05-02-14 11:33 AM
tomtsops
Performance
02-07-11 04:15 PM
Quick Reply: Anybody care to explain how PPE and Sikky "O2" conditioners work?
