Car wont start AGAIN
Old 04-30-14, 06:39 PM
Gee2anIS
Gee2anIS's Avatar
Default Car wont start AGAIN
I don't drive my car, maybe start it every 2 weeks and I started it a week ago, and went to turn on my car and it wouldn't start
Battery is a month old
Any suggestions?
Old 04-30-14, 06:43 PM
DaveGS4
Forum Administrator
DaveGS4's Avatar
Received 2,128 Likes on 1,298 Posts
Have you considered getting a trickle charger?
Old 04-30-14, 07:29 PM
vbb
vbb's Avatar
I've had to jump my car twice as well. Once I was playing with my stereo a little too long with the engine off, and the other I hadn't started it in about 10 days. Seems as if the battery gets drained faster in this car than others I've owned. A trickle charger would be a good idea if it routinely sits.
Old 04-30-14, 08:23 PM
revolut1on
revolut1on's Avatar
My battery just died as well cause I also rarely drive mine.
Go get a trickle charger or disconnect the battery.
Old 04-30-14, 09:05 PM
digger08
digger08's Avatar
Just get a battery minder.
It will keep a constant state of charge and throw random current to keep the cells active and reduce lead sulfate on the plates.
Digger08
Old 04-30-14, 09:33 PM
Lexura1414
Lexura1414's Avatar
I have left my car in hibernation mode for 3 weeks many times during winter. It starts every time. Knock on wood.
Old 04-30-14, 10:04 PM
revolut1on
revolut1on's Avatar
What digger08 posted
Have mine currently plugged in to one of those.
Old 05-01-14, 02:29 AM
Gee2anIS
Gee2anIS's Avatar
thanks guys great suggestions….
Just found out the battery is 7months old n within those months I only drove my car 1000 miles so I guess hardly ever using my car, I should start it up every other day
Old 05-01-14, 06:22 AM
digger08
digger08's Avatar
Starting a car will not replenish the battery charge, only maintain what charge is left. The cars alternator is not a charging device.
Buy a battery minder and maintain the system properly during storage periods to prevent the parasitic drain your are experiencing
Digger08
Old 05-01-14, 08:13 AM
jsfullr
jsfullr's Avatar
So odd, I just had to jump start my car last night too. Maybe its the warm weather?
Old 05-01-14, 10:49 AM
chris6878
chris6878's Avatar
happened to me after car was in the garage for 6 days.. i used this
Amazon.com: Jump-N-Carry JNCAIR 1700-Amp 12-Volt Jump Starter with Power Source and Air Compressor: Automotive Amazon.com: Jump-N-Carry JNCAIR 1700-Amp 12-Volt Jump Starter with Power Source and Air Compressor: Automotive
Old 05-01-14, 03:09 PM
WillRockwe
WillRockwe's Avatar
This doesn't make sense, batteries don't die after a month.
Old 05-01-14, 06:03 PM
TURBO5DAVE
TURBO5DAVE's Avatar
Ive seen many batterys go bad after a month. Usually old ones that were on the shelf awhile and sold or neverstarts from walmart are horrible. Id takebit to local parts store the can do a free batt test for you.
Old 05-01-14, 07:14 PM
pc1990
pc1990's Avatar
I've went two long periods without starting my F before, once for a month and another for 6 weeks. Both times the car started up fine.
akafixture
03-12-17 02:23 PM
isthrizzy
05-01-13 05:43 PM
cdvmagic
Maintenance
11-27-06 11:38 AM
Hameed
Maintenance
05-21-06 08:06 AM
tmf2004
01-08-06 09:36 PM
Quick Reply: Car wont start AGAIN
