help on different tire specs
Old 03-16-14, 08:31 AM
Compthis
Compthis's Avatar
Default help on different tire specs
I can get a really good deal on a set of Michelin Super Sports but was wondering if they will fit and will be ok for my F
FRONT SIZE
225/35R19 (88Y) XL
REAR SIZE
265/30ZR19 (93Y) XL
The tire size and load rating is slightly different in both cases . will this setup be safe?
Old 03-16-14, 04:56 PM
lobuxracer
Tech Info Resource
lobuxracer's Avatar
Received 3,847 Likes on 2,332 Posts
I would not run those tires. They are significantly smaller diameter than the stock sizes which means rim damage is more likely if you hit a hole in the road.
sld
Wheels, Tires & Brakes Forum
01-23-03 02:39 AM
Quick Reply: help on different tire specs
