PPE header & CEL
Old 05-19-14, 10:07 PM
  #61
RCB
RCB's Avatar
That's a good approach. For my header installs I use a similar product called DEI fire sleeve.
I also route the harness up along the transmission harness on the left side and up behind the heat shield then along the Trans cooler lines on the right side. It helps to take the o2 brackets out of the way as well. This keeps the extension harnesses far away from the heat. Using heat shrink or tape at the connectors and zip ties along the length of wire will also help prevent a failure down the road.
If you look closely you can see where the connector is in this picture and also how far away from the heat source my wiring is.
Old 06-28-14, 06:35 PM
  #62
sleepyray
sleepyray's Avatar
Oh no.....
it happened to me now... I was driving home from work.
CEL and Check VSC lights just came on
I got my PPE headers and installed this February and it was fine the whole time....
I going have to drop it off to find out what's the problem this Monday.
Old 06-28-14, 08:44 PM
  #63
flowrider
flowrider's Avatar
Received 1,829 Likes on 1,291 Posts
^^^^Did you happen to check the code?
Lou
Old 06-29-14, 01:12 AM
  #64
ISFpat
ISFpat's Avatar
I've had p0138 after PPE header install for weeks, hopefully its just a o2 conditioner problem.. has anyone had the same issue?
Old 06-29-14, 08:57 AM
  #65
Mrd916
Mrd916's Avatar
Where are u guys getting ur headers installed at? I'm having Lexus dealer install mine and hoping they know how to install the wiring part correctly so it won't get melted. Wondering if it's a design flaw the way the wiring is. I contacted Paul at PPE and hopefully he can walk the installer thru any issues.
Old 06-29-14, 11:56 AM
  #66
sleepyray
sleepyray's Avatar
Lou
Hi Lou...I just got back from Auto Zone, their code reader showing : P2238, Bank 1, Center 1 Sensor.
any idea?
I have mine installed by a experienced mechanic at my local dealership .
Old 06-30-14, 06:02 AM
  #67
sleepyray
sleepyray's Avatar
This Morning i woke up... the CEL and VSC lights are gone......
and i already ordered two AF sensors just in case.. ugh.
Old 06-30-14, 06:43 AM
  #68
Mrd916
Mrd916's Avatar
Hey Sleepray do u have the part numbers for the A/F sensors u ordered? I may jump on Amazon and order a pair just in case. I assume u bought Denso?
Old 06-30-14, 07:37 AM
  #69
sleepyray
sleepyray's Avatar
This is the one i ordered... I hope i didn't order the wrong one lmao
Amazon.com: Denso 234-9048 Air Fuel Sensor: Automotive Amazon.com: Denso 234-9048 Air Fuel Sensor: Automotive
it's Denso 234-9048 Air Fuel Sensor
Old 06-30-14, 07:53 AM
  #70
Mrd916
Mrd916's Avatar
I assume both sensors are same part number and I should just buy 2 of the same one right?
Old 07-03-14, 11:21 PM
  #71
RedlineAZ
RedlineAZ's Avatar
Great info in this thread! I am considering headers and now I know how to narrow down potential issues!
Old 07-07-14, 03:42 PM
  #72
Mrd916
Mrd916's Avatar
Just picked up car from Lexus of Tampa after header install and wow, what a difference in sound and performance. Master tech said install went flawlessly with no codes. I had planned on installing high flow cats but they didn't arrive with the headers so I am running catless right now. Haven't smelled any gas smell in the car even with windows down. I stuck my nose near exhaust and there is a faint exhaust smell but nothing I would have noticed unless I was an inch from the tailpipe. So far I am loving it and the sound at WOT is just unreal with the Joe Z exhaust
Old 07-08-14, 06:51 AM
  #73
sleepyray
sleepyray's Avatar
My CEL and VSC lights coming on and off lately, the mechanic who installed the the PPE for me just checked the car, the harness are good, no burn marks or anything. He help me replaced the Bank 1 Sensor 1 AF sensor just in case. Hopefully it won't come back on again. Big Thumbs up for Casey at my local dealership for excellent work!! I will keep you guys posted with the update.
Good luck on the rest of ya'll who having this issue.
Old 07-08-14, 08:06 AM
  #74
Compthis
Compthis's Avatar
I had the same issue, harness looked good so I replaced the sensor only to have the cel return. I replaced the harness and all good. I think maybe the contacts are made with an inferior material but what do I know.
Old 07-08-14, 09:43 AM
  #75
RedlineAZ
RedlineAZ's Avatar
This may be a dumb question to ask in this thread...but anyone experience this with Sikky headers?
Quick Reply: PPE header & CEL
