2014 isf will not start
Old 01-29-14, 08:29 AM
yishin
yishin's Avatar
Originally Posted by jlam86
I would poke around and try to make sure all the sensors and harnesses are fully clipped in especially in the areas where your mods were located.
Its joe z intake tube n exhaust with sikky header which area should i really look for ?
Old 01-29-14, 08:33 AM
yishin
yishin's Avatar
Originally Posted by NYKnick101
I had a similar issue with a different car, how long ago did you install the headers? Was the O2 sensor on the header re installed correctly? (if there is one) Sometimes the metal from aftermarket headers can fry the wires. Sometimes you have to extend the wires on them. Bad O2 sensor can give the car the wrong A/F ratio which can cause the car not to start
O2 was brand new that was on my original 2014 isf eith loke 700 miles
Old 01-29-14, 11:11 AM
NYKnick101
NYKnick101's Avatar
But with joe z exhaust n sikky header install
Which wire should i check for and how do u tell the o2 sensor is install correct?
No remote starter
O2 sensor could be new but like said before, it could be just a wire on something that burnt or something. The OEM headers usually has a heat shield over it that protects that, aftermarket headers don't.
If you can reach the O2 sensor from the bay i would make sure with a wrech that it is screwed on properly and tightly and then trace back the wire and see how that is mounted in the bay
Old 01-29-14, 07:26 PM
gemini1
FNM President
gemini1's Avatar
Have any pics of your 2014 IS F?
Old 01-29-14, 09:49 PM
DrRick
DrRick's Avatar
Did I meet you at Caffeine and Octane earlier this month? White with full CF kit?
Old 01-30-14, 03:57 AM
yishin
yishin's Avatar
Yes and now i do have fianl full cf kits now
Old 03-02-14, 05:39 AM
yishin
yishin's Avatar
Just for the update
It did happen again last night
I did indeed drive hard then park the car
After 20 min I start the car same issue it cranks but not start
Call the bunch friends
So guess it's down to due to my sikky header install
My shop telling me it is possible that the o2 simulator may be defected
Well wtf.....I am gonna talk justin over at sikky or
Do we have to use o2 sim? Not the o2 sec spacer ?
Bsavage
06-21-19 10:51 AM
tsx2isF
IS F (2008-2014)
40
07-05-17 08:57 AM
calteg
IS F (2008-2014)
14
02-16-15 11:01 AM
yishin
IS F (2008-2014)
03-02-14 04:43 PM
rocketship
08-30-10 11:36 PM
Quick Reply: 2014 isf will not start
