Aftermarket Brake rotors?
Old 01-15-14, 08:57 AM
Stubagg
Stubagg's Avatar
Default Aftermarket Brake rotors?
Hey everyone I'm looking for new brake rotors. Please post me some links of some aftermarkets brake rotors. I'm looking to get some that are better than the stock ones, but not too expensive.
thank you
Old 01-15-14, 10:02 AM
zapa
zapa's Avatar
Here are my new rotors! 2 piece
http://shopfigs.com/v1/index.php?rou...product_id=125
Hope that helps
Old 01-15-14, 10:43 AM
iH8RICERZ
iH8RICERZ's Avatar
The cheaper/cost effective alternative is to go with Raybestos Rotors. Many of the F guys have found these comparable to the OEM stock rotors as far as quality and fitment.
Old 01-15-14, 11:14 AM
ISF4life
ISF4life's Avatar
OEM best choice for rotor
Old 01-15-14, 11:17 AM
lobuxracer
Tech Info Resource
lobuxracer's Avatar
Received 3,854 Likes on 2,337 Posts
Brembo makes these for Raybestos. They're every bit as good as the Lexus branded units. Lexus rotor prices have dropped like a rock recently. Pretty surprising.
Old 01-15-14, 12:09 PM
itsmike177
itsmike177's Avatar
I just purchased both front rotors from Sewell and they are $110 less than 1.5 years ago.
I was looking at the Raybestos rotors, but the price difference is only $40-50, so went with genuine OEM in the end.
Old 01-15-14, 02:02 PM
toky916
toky916's Avatar
I like those figs ! How do they compare to the stock last longer don't grove ?
Old 01-15-14, 06:27 PM
mikellucci
mikellucci's Avatar
2 piece / Figs is the way to go esp. if you want to drop some weight
Old 01-15-14, 11:05 PM
ISFFF
ISFFF's Avatar
2 piece Figs is the way to go. Not only, they are better but they really last longer! Believe me they worth the extra money you pay for them. I already went through many sets of OEM rotors and I know what I'm talking about.
Old 01-16-14, 03:57 PM
JT2MA71
JT2MA71's Avatar
Received 1,518 Likes on 659 Posts
FIGS FTW! I'm using Porterfield R4S pads with mine.
Old 01-16-14, 07:12 PM
Wink
Wink's Avatar
Dixcel make replacements
Part number:
3159116 - Cross drilled (as factory spec) street performance rear rotors
Link:
http://www.dixcel.co.jp/en/rotor/
Old 01-16-14, 11:25 PM
Just F Me
Just F Me's Avatar
I've switched to using Centric Parts for my rotors…no problems here! They're about $100 each.
Old 01-19-14, 11:41 PM
FIGS
The Maker
FIGS's Avatar
Thanks for posting up guys. I actually have 6 hard track days on the first set I built up and they are still wearing extremely well. The alloy iron formula used in the ring is huge step above the OEM and you will never see the weird radial grove lines the Brembo's develop in our rotors either. This is with a pretty aggressive XP20 Carbotech track pad, not the best shot but you can see they are holding up well for what I put them through. The pad deposits center in the middle of the ring so its a little tricky to see the details on the rotor face. I should post up an update on the blog. Big pic so you can zoom in.
__________________
Redefining Lexus Aftermarket Parts Since 2001
-- We are your Lexus suspension experts--
BCR - KW - PENSKE - OHLINS - HKS - GREDDY - STANCEPARTS
Links - Arms - SuperPro Poly Bushings - Solid Bearing Conversions - Motor Mounts
RB BBK's and 2P Rotors, G-Loc pads, Radium Fuel Systems
Custom Fabrication Design and Machining - Industrial 3D Printing - Laser Cutting
2018 USTCC Sportsman Class Champions - 2018 NASA ST5 National Champions
Old 01-20-14, 02:23 AM
zazzn
zazzn's Avatar
Hrm, I just picked up the stocptech centric parts from Rock auto @ 83 each you can't really go wrong. If they warp I don't mind junking them for that price damn. How is it there is probably about 2x the metal in these vs my 87 supra rotors but yet they are nearly the same price lol,
How much are those 2 piece parts? Off topic a little but I see your caliper paint has seen better days as well Figs.. My clear coat has mostly removed it's self form both sides and it's looking pretty tired, How do you guys recommend to refinish? Do you just have them powder coated? I've never seen a high temp clear coat paint, I used to use the enmanal paint for my other car's calipers but I don't want to do that to the F.
Old 01-20-14, 07:55 AM
FIGS
The Maker
FIGS's Avatar
Yeah the coating is pretty done at this point. I was working on a new caliper with upgraded pistons and seals so I am not worrying about it. The proper method would be disassemble and powdercoat or cerakote. Then rebuild with new seals.
Quick Reply: Aftermarket Brake rotors?
