Anyone have this problem? (low coolant, overheating)
Old 01-04-14, 01:42 AM
HellaInc
HellaInc's Avatar
Default Anyone have this problem? (low coolant, overheating)
While driving my car today for about 20 minutes at a stop light I look down and noticed my engine temperature all the way maxed out bars and blinking. I immediately pull over and left the engine on and pop my hood, no thick smoke or anything coming out and I ran back inside to check and the temperature went right back down to normal. It continues raising and dropping back to the middle every once in awhile. I notice my radiator fan comes on when it shouldn't be because I don't have the AC on or anything. My heater also doesn't work it only works when I'm idle at a stop and it blows cool air once I start driving. What could be the problem? A bad thermostat or failing water pump?
Old 01-04-14, 03:59 AM
WillRockwe
WillRockwe's Avatar
You didn't mention whether you checked your anti-freeze, I assume you did
Old 01-04-14, 05:05 AM
vbb
vbb's Avatar
I had a very similar problem years ago with another car, and it was the heater core. That car was over 10 years old though. Never heard of that happening on an ISF.
Old 01-04-14, 05:25 AM
IsfClyde
IsfClyde's Avatar
probably low coolant due to leaking waterpump.
Old 01-04-14, 06:44 AM
mikellucci
mikellucci's Avatar
Could be anything from a slow leak in the radiator to the water pump to the thermostat to the coolant temp sensor, etc. I'd bet on a leaky slowly dying water pump though.. Check for hardened pink coolant formation around your engine where the WP could be leaking.
I've had each of the above components fail at some point or another on my 2jzgte and other toyotas.
Old 01-04-14, 10:09 AM
lorenr
lorenr's Avatar
Wink Get that car to the dealer
Seriously, running that car with the engine temperature that high is very bad. It will not fix itself.
Those things have happened to me before.
Check coolant level by removing the radiator cap when it is cold.
Check the overflow tank. If the contents show normal, still check the radiator.
Thermostat could be "not opening" as required.
Heater not working suggests it is not getting coolant.
For some reason you have low coolant. This is the reason you have a warranty.
Old 01-04-14, 10:17 AM
ming15237
ming15237's Avatar
The engine is VERY low on coolant, DO NOT DRIVE! Until you have addressed the low coolant issue. ONLY check coolant with engine cold. DO NOT remove cap when the engine warm or hot. Once you have addressed the low coolant level have the dealer address the coolant leak.
Old 01-04-14, 10:48 AM
NYKnick101
NYKnick101's Avatar
its definitely low coolant.
Old 01-04-14, 11:04 AM
Joe Z
Joe Z's Avatar
Received 1,058 Likes on 586 Posts
Get some ASAP...!!!
~ Joe Z
Old 01-04-14, 11:44 AM
HellaInc
HellaInc's Avatar
I am bringing in the car to see what's wrong today. I did drive for a little more yesterday after the engine temperatures started staying stable. I do notice that my radiator fan is on the whole time I am driving though. Hopefully nothing too bad.
Old 01-04-14, 12:20 PM
DCoolBeans
DCoolBeans's Avatar
I like how everyone said check the radiator fluid ………..and you haven't smh
Old 01-04-14, 02:27 PM
zapa
zapa's Avatar
It takes far to much time to pop the hood and check the level…
Old 01-04-14, 04:34 PM
lobuxracer
Tech Info Resource
lobuxracer's Avatar
Received 3,849 Likes on 2,334 Posts
^^This. Driving the car with low coolant is one of the worst things you can do to the engine. If nothing else, put coolant (or distilled water) in the coolant tank until you can get it to the dealer for repair.
Old 01-14-14, 11:05 AM
HellaInc
HellaInc's Avatar
UPDATE: I did fill up the coolant to full until I was able to bring it in to the dealership. Service advisor called today and said they found where the leak was and it was leaking into the intake manifold valley which is why I couldn't spot any residue around when I was looking. Pretty suprised this happened on a 2012. I'm at 40k on the clock right now.
Old 01-14-14, 11:18 AM
rmillsISF
rmillsISF's Avatar
what's the cost to fix that leak out of warranty (yes, I know you're still under warranty, I'm asking for us that aren't)? Just wondering
Quick Reply: Anyone have this problem? (low coolant, overheating)
