sunroof thud clunk noise
i've searched and searched but can't really find others with this similar issue (except in the 350 forums).
when i'm turning on an uneven surface where the wheels are essentially turning on an inclined surface, i get a strange clunk from the sunroof, basically sounds like its moving around. more or less happens when the chassis is flexing. if i press up on the sunroof when going over such surfaces i can eliminate the issue....
when the sunroof is closed, if i press up on the back corner of the sunroof on the driver side, it definitely has a bit of travel that doesn't exist on the drivers side.
any ideas here? probably going to have to end up removing the headliner i guess?
thanks!
thanks!
I think I have the similar issue. It has gotten worse in the cold.
i have not isolated if holding on the corners made a difference.
I thought it was the roof's metal flexing? , unfortunately no warranty left either
funny enough I was searching the last couple days for the same thing...
Most posts were by the IS300 crew of noise in the sunroof
i will definitely update once i get this resolved. i don't want to remove my headliner, but yet don't really trust anyone else to do it either, what to do what to do.....i think the passenger side sun roof rail is loose is my suspicion.
when you press on your sunroof from the inside does it travel at all?
Mine is more towards the back. Center and passenger SIDS that I feel some play.
Looks like it could be a combination of the rear drip catch bar and sunroof. Still don't fully know. All I know is I reached my hand and pushed random spots. At first it made it better but now it seems to be getting louder lol.
