PPE Full Exhaust System with Dual Mode Muffler
Old 07-07-14, 07:28 PM
  #166
flowrider
flowrider's Avatar
Received 1,829 Likes on 1,291 Posts
I'm away from home right now, on a trip to Lake Arrowhead. Anyway, I am still driving with the system open most of the time. But, I discovered a benefit of the closed feature that I hadn't thought of. While driving over here, I got a phone call. The drone from the exhaust although pleasant to me, would not have allowed me to talk and listen over the BlueTooth speakers, so a flip of the switch, and Yay I could use the BT and my phone in quiet comfort.
Lou
Old 07-14-14, 12:41 PM
  #167
iizzle3fiz
iizzle3fiz's Avatar
Are there still plans for mufflers that replace the stock bumper inserts?
Old 07-14-14, 01:20 PM
  #168
I8ABMR
I8ABMR's Avatar
Lou
That valved design really makes it more functional
Old 07-21-14, 03:22 AM
  #169
FraganciaF
FraganciaF's Avatar
I'm away from home right now, on a trip to Lake Arrowhead. Anyway, I am still driving with the system open most of the time. But, I discovered a benefit of the closed feature that I hadn't thought of. While driving over here, I got a phone call. The drone from the exhaust although pleasant to me, would not have allowed me to talk and listen over the BlueTooth speakers, so a flip of the switch, and Yay I could use the BT and my phone in quiet comfort. Lou
I been having a strong odor problem after installing the system wanna know if this is normal or what can I do to fix the issue I'm cat less I will like to know if adding the cats will delete that strong odor inside the cabin Just wanna make sure that adding the cats will fix the smell so I don't pay 300 on something and still have the same odor inside,is so strong that after I get off the car I can smell it on my clothes ..somebody told me that the problem is that the exhauts doesn't go all the way out to the tips and that's why all the smoke stays under the car and go inside the cabin he said to add a lil extra pipe to make it reach the tips .. Do u think that would work ? I can't stand that smell
Old 07-21-14, 06:34 AM
  #170
4TehNguyen
4TehNguyen's Avatar
does it smell like gasoline? No cats will give you more of a gasoline smelling exhaust sort of like an old classic car.
Old 07-21-14, 08:29 AM
  #171
FIGS
The Maker
FIGS's Avatar
We are in the process of documenting the install and should have some prelim sound clips today. FraganciaF the secondary cats are there to soak up additional unburnt fuel. Since you have both the headers and the exhaust and are completely catless the smell you are getting is a result of that residual fuel coming out the exhaust. Cats should eliminate the issue.
Mike
__________________
Redefining Lexus Aftermarket Parts Since 2001
-- We are your Lexus suspension experts--
BCR - KW - PENSKE - OHLINS - HKS - GREDDY - STANCEPARTS
Links - Arms - SuperPro Poly Bushings - Solid Bearing Conversions - Motor Mounts
RB BBK's and 2P Rotors, G-Loc pads, Radium Fuel Systems
Custom Fabrication Design and Machining - Industrial 3D Printing - Laser Cutting
2018 USTCC Sportsman Class Champions - 2018 NASA ST5 National Champions
Old 07-21-14, 10:16 AM
  #172
flowrider
flowrider's Avatar
Hi Guy. Yes, the addition of HiFlow Catalytic Converters will eliminate the gasoline odor you are smelling. The cats are an option on the PPE system, and I have that option, and have absolutely no smell. As far as the gap at the rear of the tailpipes causing the gasoline odor, that's bull.
Lou
Old 07-21-14, 12:33 PM
  #173
wmjeffreyw
wmjeffreyw's Avatar
I had Paul with PPE customize my exhaust so I could run either with or without cats. Speaking from experience, the PPE HFCs will eliminate the exhaust odors. I went about 2 weeks before I got tired of the exhaust smell and put on the HFCs. I could feel a slight decrease in power on the high end but I actually think I gained a little low and mid range torque.
Old 07-21-14, 02:19 PM
  #174
FraganciaF
FraganciaF's Avatar
Originally Posted by FIGS
We are in the process of documenting the install and should have some prelim sound clips today. FraganciaF the secondary cats are there to soak up additional unburnt fuel. Since you have both the headers and the exhaust and are completely catless the smell you are getting is a result of that residual fuel coming out the exhaust. Cats should eliminate the issue. Mike
oh ok thanks I guess I got no other option then to order the cats and loose some power :-(
Old 07-21-14, 02:51 PM
  #175
Sean
Sean's Avatar
Don't forget to check the member classifieds.
Old 07-25-14, 09:16 PM
  #176
FIGS
The Maker
FIGS's Avatar
one of the pics from this past week.
__________________
Old 08-19-14, 07:56 AM
  #177
yosacchmo
yosacchmo's Avatar
Any idea how close this exhaust is to being released for purchase? This is exactly what i've been looking for i've been playing with different cut out options so I can be loud and obnoxious when I want and still have some refined luxury when i want as well. Even just being able to buy the mufflers or find a similar muffler would be great.
Old 08-19-14, 11:11 AM
  #178
FIGS
The Maker
FIGS's Avatar
We can take orders now, just working through a few last details and should have the sound clips up. With resonators and cats the system is very mellow with 0 drone. When closed its pretty much a stock sound, or lack of sound
__________________
Old 08-19-14, 11:14 AM
  #179
I8ABMR
I8ABMR's Avatar
how much will the system cost? Is this a new Figs system ?
Old 08-19-14, 11:56 AM
  #180
flowrider
flowrider's Avatar
^^^^It's the PPE system. Figs is an authorized distributor.
Lou
Quick Reply: PPE Full Exhaust System with Dual Mode Muffler
