Offset ? Before purchasing
Hey guys I'm looking at pulling the trigger on a set of BC forged wheels hp 29.
Would 19*9 +28
19*10 +38
How aggressive would this be?
Will be rummimg slight stretch with a slight drop.
Will any fender mods be required?
Will consider fender mods if necessary.
Thanks in advance.
Would 19*9 +28
19*10 +38
Thanks in advance.
Fronts should be fine. I'm on 19x10 +40 with 265/35 pilot super sports in the rear with very slight rub on big bumps or deep drive ways and such. My fenders are rolled almost flat, however pilots are fat tires so that's likely the reason I rub. I'd say your specs are nearly perfect with the right sized tires and a good roll.
The BCs look great, and I was also looking at the HB-29 as my next set. The fronts will most likely need a roll. I'ave seen a few F's with mid to hign 20s in the front, and I think most of them had fenders rolled are stretching a bit. The rears are what I think is just right for the wells without having to do anything, even with a drop. But to be on the safe side, I would still roll. I'm with Pqbrown- the PSS are chunky, and I, too, hear the occasional rub on bumpy roads. I know they'll look good though!
Question gurus, how will my offset change is if I decide to go .5 wider? For example if I go 19x9.5, how would I change the offset? Would it still be +28 still, if I wanted to originally go 19x9 +28
I have BC Forged HB29 they are custom order but in the end you will have to pick whats offered from factory. I am dropped on BC Racing coils. Index finger gap all around. I do not rub and I have no fender mods of any kind. I am a firm believer on sticking to wheels that are better than OEM and with wheels that actually fit without modifications.
For example what I picked was
19X9 +30
19X10 +40
I believe the options were
19X9 +30 or +35
19X10 +35 or +40
19X9 +30 was almost flush with fender. Could be more aggressive.
19X10 +40 is flush with fender. +35 will have some poke. You will have to do some stretch.
19X9 +30
19X10 +40
19X9 +30 or +35
19X10 +35 or +40
bluerex, going .5 wider with the same offset would be 6mm or about 1/4 inch wider. Should you decide to keep the same sizing with 19 x 9.5, a +34 would negate that 6mm poke. Did you have tire sizes in mind already?
Ivan at PYspeed was great. I paid just a little north of $3000 for the set without tires. 6 week wait.
