Throttle position sensor
The TPS (there are two) is built into the throttle body, and is not normally serviced. If you find the sensors are in fact bad, you can replace the entire unit. Or, if a little more adventurous, parts from another Toyota DBW throttle body can be utilized, you'll need to drill out some rivets to remove the parts.
International FS: Throttle Convert Kit 2JZGTE-VVTI
rush161
17
09-03-17 10:47 AM
2JZSoarer
Performance & Maintenance
08-08-04 03:31 PM
