Rear Bumper removal - under panel discovery....
Old 05-20-13, 05:53 PM
digger08
digger08's Avatar
Default Rear Bumper removal - under panel discovery....
Ok…while removing my bumper to install the Wald rear diffuser…… I discovered to my horror …..(after 100,000 miles and almost 5 years)
…Massive road and tire debris, tar and industrial fall out from brake dust caked on the under panels on each side was the worst and also along the back above the crash bar.
I couldn’t in good conscience put the bumper back on without cleaning this up.
I also pulled out the panel vents/ drains and cleaned inside of the panel…apparently this drains stuff from the trunk, Cause this is what I found inside of the vent?
Items found inside of the vent pocket
I also found this weird looking rusted out bracket, must be associated with rear parking sensors, as I first thought it maybe was put there by the previous owner, but when I removed it, I saw it was engineered to fit in its place by Toyota.
For clean up… I started with some clay bar and lubricant…nope.
Then moved on to some Castrol Superclean to see if it would dissolve the tar better…nope.
I then landed on some “NeverDull, soft Steel wool cotton wadding…this did the trick.
I then used a paint sealer and coated the panels to make the next clean up easier.
I’m not saying that your car will be like mine…..but I’m glad I found it before the rot sets in.
Happy to be back together
Thanks for looking.
Digger08
Old 05-20-13, 06:09 PM
FD3SISF
FD3SISF's Avatar
Good thing you took out your bumper.
Old 05-20-13, 08:30 PM
lobuxracer
Tech Info Resource
lobuxracer's Avatar
Received 3,835 Likes on 2,324 Posts
I would have tried Iron-X on those spots. Looks like hot brake pad material just like we see on the wheels.
I noticed a lot of junk collecting in this space - wet leaves, road debris, and other junk you would not want to remain resident. That bracket looks really bad though, like it was never protected at all.
Old 05-20-13, 09:03 PM
BlueMicaF
BlueMicaF's Avatar
Wow crazy find! After all those years I guess it really builds up under there. Diffuser looks good
Old 05-20-13, 09:39 PM
bnizzle87
bnizzle87's Avatar
Crazy to see all that underneath the bumper. I'm probably going to do the same thing when I take the bumper off. The WALD rear looks fantastic!
Old 05-20-13, 09:51 PM
CalitriSC
CalitriSC's Avatar
Damn crazy! Let me get that Wald diffuser from you though
Old 05-20-13, 10:16 PM
edgeucated
edgeucated's Avatar
im starting to like the vinyl-wrap-license-plate-area fad.
Old 05-21-13, 07:16 AM
digger08
digger08's Avatar
LiLS was the first one I saw......... and used his build as my inspiration as he has a beautifully built car.
Digger08
Old 05-21-13, 07:21 AM
LexusNN
LexusNN's Avatar
Looks good all cleaned up. That never dull stuff works wonders. Diffuser looks awesome
Old 05-21-13, 09:09 AM
zmcgovern4
Auto Detailing Master
zmcgovern4's Avatar
Iron-X or TRIX would have been the best products to use... simply spray them on and they will dissolve the fallout/iron particles and tar. Then wipe/rinse clean. Pretty great products.
Looks good though! Nice of you to actually worry about cleaning those areas up. Most people wouldn't care enough to clean the non-visible areas of the car.
Old 05-21-13, 09:43 AM
GriMan
GriMan's Avatar
nice finding. i like your license plate. lol
Old 05-21-13, 10:16 AM
lobuxracer
Tech Info Resource
lobuxracer's Avatar
That weird rusted out bracket is a mount for the wire harness for the parking sensors. If you don't have them, you can remove it entirely.
Old 05-21-13, 11:06 AM
digger08
digger08's Avatar
Yes I can,...... just a simple screw is all that holds it...I do not have parking sensors on the car (Canada delete option) so I assume it must have something to do with that?
Digger08
Old 05-21-13, 08:08 PM
CUTigers
CUTigers's Avatar
That vinyl section does look good. im jealous
finny76
GS F (2016-present)
11-26-19 11:02 AM
ItsNichola
RX - 3rd Gen (2010-2015)
10-12-17 08:22 PM
myonoshane
06-07-15 07:40 PM
Cobra1
IS F (2008-2014)
04-29-14 06:36 PM
jat0223
IS F (2008-2014)
02-23-13 01:13 PM
Quick Reply: Rear Bumper removal - under panel discovery....
