accelerating from deadstop
Old 05-14-13, 02:03 PM
  #31
ISF4life
ISF4life's Avatar
Newbie is a newbie
Old 05-14-13, 02:16 PM
  #32
Just F Me
Just F Me's Avatar
Originally Posted by chrisp1
for the record the suspension changes and torsen lsd started in the 2011+ models. One of the reasons I bought a 2011
Word of advice since you're new to the forum...
Perhaps you should have said ..."I read in car and driver that 2011+ models got suspension upgrades as well as torsen LSD...is this true?" Instead you come out and straight up say "_________________" .
Not sure how old you are...most of the IS F members here are older, somewhat more mature (excluding me, I'm 14). A lot of them have had their cars for a few years and have been on this forum a lot so generally they know what they're talking about.
see the enclosed article by car and driver under the section a thorough revamp. They talk about how the suspension totally changed and the torsen lsd replace the open diff
http://www.caranddriver.com/reviews/...ad-test-review
I guess im the type that believes what the pros write in car magazines I could definitely be wrong, im just going by what im reading.The article below from car and driver must be wrong or a typo then. It says the torsen limited slip replaced 2010s open differential setup. http://www.caranddriver.com/reviews/...ad-test-review
A lot of car magazines are idiots. You can only take so much from it. Perhaps since you're new to the forum, might be good just to lay low and read for awhile before you come out and say with 100% certainty before you state something.
BUT HEY! Now you know 2010 on up got suspension upgrades as well as an LSD.
Old 05-14-13, 04:20 PM
  #33
ISF001
ISF001's Avatar
Originally Posted by Just F Me
This is incorrect...2008 models do not have LSD. If I'm not mistaken, it's 2010+ that have LSD. Second, 20 degrees is way too fricken cold for tires. If you're talking 20C, then I think that's almost like 70F, which isn't very hot either....warm up the tires.
Secondly...what tires are you running?
You're not mistaken. The Torsen LSD was first installed with the 2010.
Old 05-14-13, 06:08 PM
  #34
Gymkata
Gymkata's Avatar
This thread is ridiculous and has given me my biggest laugh yet today...thanks guys. It is always fun listening to uninformed people have it out with informed people with a chip on their shoulder...lol.
Old 05-14-13, 06:43 PM
  #35
vbb
vbb's Avatar
Agree. And my thought is that the OP's issue is more related to tires than anything else. When I take off from a stop I always roll into it a bit rather than just stomp the accelerator.
Old 05-14-13, 07:18 PM
  #36
VtotheJ
VtotheJ's Avatar
OP must be like WTF.....I asked a simple question and now people are arguing about when the LSD first came out?!?!?!
Old 05-14-13, 07:23 PM
  #37
nsx042003
nsx042003's Avatar
I checked the tires and they are still good. Haven't checked tire pressure yet, but I did an alignment a few weeks ago and tire pressure were all up to 35 psi.
I also meant 20C as i'm in canada :P haha
Old 05-14-13, 10:24 PM
  #38
SeanGTS
SeanGTS's Avatar
I was going to say.. 20 degrees in Washington? Its been beautiful here.
Old 05-15-13, 05:25 PM
  #39
lobuxracer
Tech Info Resource
lobuxracer's Avatar
Received 3,838 Likes on 2,327 Posts
Check for a blown shock. These cars are pretty stable off the line even when you punch it, so I'd be looking at the suspension components to be sure nothing is bad or weak.
The Torsen LSD was a change for 2010. The eLSD works pretty well but does not work under 15 mph, so it won't help with a launch. Do the pedal dance if you want to see what open diff really means. Also, we have "pretorque" washers in the spider gears of the open diff on the '08 and '09 which makes it behave more like a Phantom Grip than a true open diff.
Check your tire pressures, be sure your rear toe is correct and thrust angle is as close to zero as possible. Check your shocks to be sure they're not leaking (excessively), and if all else fails, corner weigh the car. It's possible the springs are a bit off from the factory.
Old 05-16-13, 09:11 AM
  #40
SeanGTS
SeanGTS's Avatar
Man, it would be cool if you could walk us through those steps and hold my hand. lol
Old 05-17-13, 02:08 PM
  #41
nsx042003
nsx042003's Avatar
thanks for the leads, lobuxracer. It's still a mystery to me, it might just be the tire pressure, or the crappy uneven road surfaces we have in Vancouver. I don't suspect the shocks, as I just put in new BC coils, and rear toe and thrust are pretty much 0 according to the alignment readout.
Old 05-17-13, 04:47 PM
  #42
lobuxracer
Tech Info Resource
lobuxracer's Avatar
You might want to have the springs tested. Very few aftermarket springs are well matched. This is why Hypercoil is the racer's choice. They deliver as advertised. Most of the others are +/- 10% (or more) so you could have wildly different spring rates.
Davesisf08
IS F (2008-2014)
06-18-19 11:11 AM
2GRFE
IS F (2008-2014)
14
11-11-15 06:23 AM
chikoo
Road Course and Auto-X
01-19-12 04:54 PM
SuperG
09-02-08 09:47 PM
Pearlpower
Performance
10-25-04 08:12 AM
Quick Reply: accelerating from deadstop
