Brake system flush ... How difficult is it?
Old 05-13-13, 06:35 AM
Ascari_2
Ascari_2's Avatar
Default Brake system flush ... How difficult is it?
Hey everyone,
Question about doing a brake fluid flush. I am a car-savvy guy and planning on doing my front rotors/pads likely later this week (something I've done countless times on other cars). However, I've never done a complete brake fluid flush. How hard is this process and what is involved? I am thinking I might just have the dealer take care of this so as not to deal with any potential air pockets or having to buy new tools. But if it is simple enough, I might just take care of it myself.
Thanks
Old 05-13-13, 09:58 AM
itsmike177
itsmike177's Avatar
Complete brake fluid flush is the same as any other car. It is simple, just takes time.
After years of DIY brake fluid flushes in the garage: jacking up the car, setting jacks stands, taking off the tires, going to each corner, pumping it via pedal or some vacuum device, I ended up taking it to the dealer. $130 with a loaner for the "hassle" is worth it to me every 30k miles.
Originally Posted by Ascari_2
Hey everyone,
Thanks
Old 05-13-13, 10:12 AM
Just F Me
Just F Me's Avatar
I've never considered working on my car a "hassle". Just quality time with the old girl
Old 05-13-13, 10:16 AM
ISFPOWER
ISFPOWER's Avatar
easy as an oil change.
Old 05-13-13, 10:32 PM
avgj0F
avgj0F's Avatar
Or $55 with Longo's Voucher of $75 Off.
Old 05-14-13, 12:58 AM
ISFFF
ISFFF's Avatar
I've done it myself... It isn't hard at all.
Old 05-14-13, 06:55 AM
Civic Si-r
Civic Si-r's Avatar
I bought this, works great and easy, just make sure you purchase the proper fitting for your application. I think it was 60 bucks and the cost of brake fluid. Simple and easy, truly a 1 man job
Old 05-14-13, 10:04 AM
flowrider
flowrider's Avatar
Received 1,829 Likes on 1,291 Posts
A great DIY, IMHO:
Lou
Old 05-14-13, 09:10 PM
lobuxracer
Tech Info Resource
lobuxracer's Avatar
Received 3,849 Likes on 2,334 Posts
It's stupid easy.
https://www.clublexus.com/forums/is-...ml#post4215699
Buy a set of solobleeders from Summit (or another source, your choice) and you'll be able to do it yourself whenever you need to do a refresh on your fluid.
Old 05-15-13, 05:13 AM
MisterSkiz
MisterSkiz's Avatar
My Power Bleeder with the Universal Attachment did not work on the F.
I bought an extra master cylinder cap and plan to make that into a bleeder cap..just haven't had time.
Old 05-15-13, 01:57 PM
DCoolBeans
DCoolBeans's Avatar
Great video Lou!
And yes its easy. The hardest part is jacking up the car and removing the wheels
Old 05-15-13, 03:17 PM
ISFPOWER
ISFPOWER's Avatar
Did anyone else thought how crazy light our calipers are?
Old 05-15-13, 03:50 PM
lobuxracer
Tech Info Resource
lobuxracer's Avatar
I'm not a big fan of that type of power bleeder. When you pressurize it, air dissolves into the fluid. The good ones use a bladder or a piston to separate the brake fluid from the air pressure. I'd rather use the pedal with solobleeders than use that particular power bleeder.
Old 05-16-13, 11:52 PM
ERDoc74
ERDoc74's Avatar
I bought the solobleeders several months ago and was going to have my car shop who did my Figs suspension parts and 2-piece rotor install do it at the same time.... However, they didn't install them due to previous "problems" they had had with them on other cars... should I ignore them and get them installed anyway?
Old 05-17-13, 10:24 AM
lobuxracer
Tech Info Resource
lobuxracer's Avatar
If you aren't bleeding the brakes, they won't get installed. There's no point for a shop to install them if they have pressure bleeding equipment they prefer to use.
Quick Reply: Brake system flush ... How difficult is it?
