finally got headers/joe z exhaust done.. now i'm paranoid
my excitement however unfortunately did not last very long, after digging up tons of old threads regarding installation issues, especially with the sikky headers. the mechanic i went to is definitely one of the more reputable places around but they have never worked on an IS F before and i'm concerned they didn't take the necessary precautions to prevent future problems. (i definitely didn't give them any pointers that would help them out so they were basically on their own)
i can't live like this lol and plan on shelling out some more money to take the car to a DIFFERENT place, just to have them go through everything and make sure there are no issues. could someone with some experience with sikky headers / joe z exhaust and intake please maybe give me a short list of things for me to tell the mechanic to check / redo. one thing i've read is to use both the sikky and oem gaskets, any other installation tips?
thank you so much, sincerely one extremely OCD is-f owner
Where are you located?
The person doing the job should already know what needs to be done before he even removes a bolt. The installation process for both are fairly straight forward and dont require much headache to knockout in a timely manner. I would just remind him not to break the o2 sensors, and to make sure that fitment isnt going to be an issue down the line. Let him know that you expect this to be the only time the headers and exhaust will require any form of installation or adjustment.
i have the exactly set up and and i'm loving every moment of it, there's no issue if the installer does his job right, make sure the simulator is wired correctly and double up on the oem gaskets + gaskets that come with after market header=make sure to tighten a bit more after some test run. Lift up and check make sure there's no leaking any oil from the dipstick. I used OEM dipstick since Sikky is notorious for that whacky dipstick lolz. Hummnn , oh use white marker to marked where is the steering shaft is original. Also spray on WD40 on those o2 sensors to loosen and gently but slowly loosen them with out damage it=take the headers out of the car and then taking 02 sensors out . Should be around 3 to 4 hrs job done right. Now go out and enjoy the beast mode lolz
i originally felt the same way, not expecting many issues but there are tons of threads picking at the quality of the sikky headers / gaskets / bolts / screws and now i can't stop thinking about it
appreciate the advice sir i will be getting that done in the next few days
sounds amazing, what's the name of the place? thank you
I will say this that unless the sealing surface is not flat there is simply no need to double a gasket. I for one wound never EVER apply anything on my own vehicle more less a customers vehicle that requires the use of two gaskets to produce a proper sealing surface. Just saying... If another manufacture created a header which offered a "square" sealing surface (even at the expense of 10hp loss) I would choose them in a heart beat!
kilawatts
27
01-20-13 04:01 PM
RX7 RAGE
IS F (2008-2014)
36
06-27-12 11:34 AM
AdamLexus
Performance & Maintenance
12
01-26-08 09:19 AM
