Oil Changes - Needing "re-clarification" or consensus.
Old 03-14-13, 05:29 PM
CarbonISF
CarbonISF's Avatar
On a more serious note, this should give you more insight and is fairly easy to read.
http://www.amsoil.com/lit/g1490.pdf
Old 03-14-13, 11:33 PM
Just F Me
Just F Me's Avatar
Originally Posted by PurduePete
Oil change at 5K miles here.....
Aand your last statement thanks.....talk about the white elephant in the room...
Yeah...it's about time you showed up
Old 03-16-13, 10:17 AM
avgj0F
avgj0F's Avatar
Why not do like this dude, Lobuxracer doing, have the oil analyzed. The Lab even willing to send the kit to you for free!
Facts trump over-killed-paranoid opinions!
Old 03-16-13, 11:52 AM
IsFactor
IsFactor's Avatar
Mobil 1 synthetic, changed every 5k as I run my car pretty hard. I'm gonna switch over to amsoil next since I hear such good things about it.
Old 03-16-13, 12:03 PM
CaliTRDSC
CaliTRDSC's Avatar
really dont matter how hard you run the car. a basic oil change is recommended every 3K. semi Synthetic is 5k and a full synthetic is 7k
so for example Castrol GTX 5w30 should only be ran no moer than 3k
Old 03-17-13, 08:42 PM
lobuxracer
Tech Info Resource
lobuxracer's Avatar
Received 3,848 Likes on 2,333 Posts
It's impossible to say what the correct interval is if you don't analyze the used oil. If you use the recommended interval, you won't go wrong unless you drive very short distances and never get the oil to temperature (3 bars on the oil temp gauge), if this is typical for you then you might need shorter than 5k changes.
So, the easy thing to do is change it at the recommended intervals (5k). I consider all the risks, and have my oil analyzed so I know with great certainty what is reasonable for my driving patterns. As always, YMMV depending on how you use the car.
goto35
IS F (2008-2014)
205
09-12-22 06:12 AM
ninten5
IS F (2008-2014)
12
09-06-20 01:50 PM
soupyb
IS F (2008-2014)
43
03-09-16 04:23 PM
agtuning
IS F (2008-2014)
18
05-14-09 02:23 PM
ngl1145
IS F (2008-2014)
06-20-08 12:59 AM
Quick Reply: Oil Changes - Needing "re-clarification" or consensus.
