Lowering springs in the front only- who has done this?
Old 03-12-13, 04:19 AM
vbb
vbb's Avatar
All the pics look great guys, thanks!
Old 03-12-13, 01:01 PM
ludedude
ludedude's Avatar
Originally Posted by Lexura1414
I am stock shocks, ludedude. We have to do a meet next month so you can see and drive my car. To the OP, considering you have aftermarket wheels, your car would look great with the swift rears installed as well. The ride and performance of the springs are very similar to stock. If you have beefier tires, they would ride better which was my experience when I had 275/30. Now that I am on 295/25, the ride is really close to stock.
Just ordered a set of Swifts after seeing this thread. I still would like to check out your car in person though!
Old 03-12-13, 01:05 PM
vbb
vbb's Avatar
Where did you order from, and how much? I'm probably going to order tonight or tomorrow.
Old 03-12-13, 01:20 PM
Lexura1414
Lexura1414's Avatar
Yup, you can check out my car. I bought mine form VIP autosalon and I did not have a pleasant experience. Hope you did not order from them. Are you doin the fronts only like VBB?
Old 03-12-13, 01:24 PM
ludedude
ludedude's Avatar
I ordered mine from a local shop that I do a lot of business through. They're not a vendor here so I probably shouldn't mention their name here.
I plan on doing the fronts and rears.
Thanks vbb for making the thread that made me spend more money.
Old 03-12-13, 01:25 PM
NYC ES3
NYC ES3's Avatar
Stiffer than Stock - NO WAY !
Non of these aftermarket springs are stiffer than the OEM spring
If anything they are softer ...
regardless of being a Progressive rate spring its not holding the weight solid of the F like the OEM's - thats where that "bouncy-ness" come from during ride.
A to B to C comparison
Swift to Eibach then Swift to Stock spring
First pic is the Swift sping vs. Eibach Spring - same thickness
then Swift to Stock OEM spring
stocks are clearly Thicker in diameter.
Attached Thumbnails Lowering springs in the front only- who has done this?-120714_011.jpg   Lowering springs in the front only- who has done this?-120714_008.jpg   Lowering springs in the front only- who has done this?-120714_007.jpg
Old 03-12-13, 01:28 PM
ludedude
ludedude's Avatar
Does anyone have the rates of the OEM springs?
Old 03-12-13, 01:30 PM
vbb
vbb's Avatar
Glad I could help.
I have heard bad things all over these boards about VIP AutoSalon, so actually I was hoping to find another place that stocks and sells them. Figs? Random eBay store. I guess I'll figure it out.
Old 03-12-13, 01:54 PM
ludedude
ludedude's Avatar
Originally Posted by vbb
Glad I could help.
PM'd you
10 chars
Old 03-12-13, 02:00 PM
flowrider
flowrider's Avatar
Received 1,826 Likes on 1,288 Posts
Glad I could help.
PPE has 'em too.
http://www.ppeengineering-onlinestor...&categoryId=35
Lou
Old 03-12-13, 02:39 PM
ShadowISF
ShadowISF's Avatar
I just found this picture. Front Eibach and rear OEM.
Attached Thumbnails Lowering springs in the front only- who has done this?-1.jpg
Old 03-12-13, 02:49 PM
Lexura1414
Lexura1414's Avatar
Nice set-up , Shadow. Perfect stance, wheels and tint.. How are the Eibachs for the OPs benefit? Do they ride stiffer? Any improvements?
Old 03-12-13, 03:00 PM
ShadowISF
ShadowISF's Avatar
Thanks. Ride is a little softer and not as stiff. Performance wise, feels the same or a bit better but didn't make it worse at all.
Old 03-12-13, 03:21 PM
zapa
zapa's Avatar
What spring rates are you going to go with up front? 12k, 14k, or 16k?
Old 03-12-13, 10:55 PM
Rossi
Rossi's Avatar
I'm only dropped in the front with Eibach springs. No complaints here. Perfect drop. Now, the front and rear gaps looks equal (about 2 fingers). Also, the ride is a bit softer in the front and performance wise, feels a little better as well.
Agree. It corners better. Eibach in front and Fsport sway bar in the rear. The car is perfectly balanced when driven hard. With eibachs in front, absolutely no problems with alignment, with drop only .7 inch, the shock life will not get as affected vs 1 inch drop of Swiffts.
Quick Reply: Lowering springs in the front only- who has done this?
